Wheel Protection?
Old May 10, 2004 | 07:56 AM
litterbox's Avatar
I am a (Trial User) Army
Default Wheel Protection?
hey,
is there any alarm that senses when the car is being jacked up, or when the lugnuts are being unscrewed. i'm looking for a way to protect my wheels other than wheel locks.
thx
Old May 10, 2004 | 08:09 AM
nOOber's Avatar
Default Re: Wheel Protection? (litterbox)
ungo used to have one. it was part of their shock sensor, if I recall. it was hard to set sensitive enough, though.
What you are looking for, is a Tilt and/ or Motion sensor. ( not a radar, or shock sensor)
let us know what you decide to go with...
Old May 10, 2004 | 08:35 AM
audioroach's Avatar
What you require is a tilt/motion sensor.
DEI has two versions available:
507T digital tilt/motion sensor
905075/60-5037 Clifford digital/tilt motion sensor
Either verson wil work with any alarm. Should run about
75.00 from your local DEI dealer.
Old May 10, 2004 | 09:26 AM
litterbox's Avatar
Default Re: Wheel Protection? (audioroach)
so a tilt motion sensor is an option that you can add onto the alarm? do you think you could get the same results if you set a proximity detector really low?
Old May 10, 2004 | 10:12 AM
nOOber's Avatar
no. what do you mean by setting it low ?
Old May 10, 2004 | 10:53 AM
litterbox's Avatar
Default Re: Wheel Protection? (nOOber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nOOber &raquo;</TD></TR><TR><TD CLASS="quote">do you think you could get the same results if you set a proximity detector really low?
i mean you set the proximity detector at a really low sensitivity setting, so it only picks up big thumps against the car or maybe the car being jacked up?
Old May 10, 2004 | 11:10 AM
nOOber's Avatar
ahhh. In that case, not a chance.
Find a tilt sensor, and it's all good.
Old May 10, 2004 | 11:24 AM
audioroach's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litterbox &raquo;</TD></TR><TR><TD CLASS="quote">so a tilt motion sensor is an option that you can add onto the alarm? do you think you could get the same results if you set a proximity detector really low?</TD></TR></TABLE>
NO!...they are to different animals. Put a prox sensor on your
car and I can still take a Nascar style Floor jack and raise the
car up,steal your wheels and drop it back on the ground...all
without triggering your alarm
. Suck to be you huh..
Its your call...you can use what will work or try to 'rig' something
that will have disasterous results.
Old May 10, 2004 | 11:31 AM
litterbox's Avatar
just finding out about options. i'll get the tilt/motion sensor
i think the prox detector is pretty useless cause most alarms chirp anyway when they sense something pushing against the car
Old May 11, 2004 | 11:01 AM
swatdog's Avatar
if you're just worried about your wheels, get a tilt sensor. When the car is picked up at an angle, the alarm will go off. Once my car is lifted about a few extra inches, the alarm will go off. DO NOT PUT A MOTION SENSOR OUTSIDE YOUR CAR. Motion sensors can be a big PITA. i havce one installed inside my car. Cats used to walk on my windshield at night and make the alarm go off. Even with my sensitivity turned all teh way down, strong random wave frequences can set off the car.
Just get a tilt sensor.
(i'm talking from experience)
Old May 11, 2004 | 02:23 PM
From: eating the shit out of pizza in raleigh, NC, USA
DEI makes it, they have one that is a digital mercury switch.
Lou_EM1
Audio / Security / Video
May 12, 2008 09:51 AM
Bangers
10
Apr 5, 2006 08:26 AM
Undepelo
22
Sep 26, 2002 05:51 PM
