whats a normal size speaker wire?
Old Aug 11, 2004 | 11:28 AM
ilikemyaccord's Avatar
Default whats a normal size speaker wire?
today i went out and bought 16gauge speaker wire for my amp installation this weekend. amping up my speakers finally!..what size should i have gotten and what size would you reccommend for the power wire? i was thinking it would be 8 guage. but im not sure.
Old Aug 11, 2004 | 11:48 AM
shyboy817's Avatar
i use 12 gauge, which is quite enough for me.. 12-14 should be fine, 16 is small for me but it should work either way..
Old Aug 11, 2004 | 12:00 PM
rcurley55's Avatar
New User
Default Re: (shyboy817)
16 is fine for speaker wire - you could even do 18 - i'd consider 12 or 14 on the higher side - I'd say 16 is just fine.
for power wire it depends on the size of the amplifier.
Old Aug 11, 2004 | 12:39 PM
Default Re: (rcurley55)
ITS A 350X4 KICKER...maybe 8 guage power wire?
Old Aug 11, 2004 | 01:21 PM
shyboy817's Avatar
8 gauge is fine for power wire
Old Aug 11, 2004 | 02:56 PM
Xsi's Avatar
Xsi
16 is fine for speaker wire, i'm using 12 for my sub. 8ga should do for the amp power wire.
Old Aug 11, 2004 | 03:59 PM
teamxtant's Avatar
Default Re: (Xsi)
Everyone has their opinions on what size wire you should use. If you want to know what size power wire you need to run, you need to first look at the fuse rating of your amp, and then measure the lenght of wire needed to go from your battery to your amp. With those 2 measurements, go to http://www.streetwires.com and go to their wire gauge calculator. it will tell you what size wire you need to run. As for speaker wire, The bigger the better. Stock oem wire it usually 18-20 ga. I like to run 16 to my speakers. For subs, depending on how many watts it will be sending to the speaker, I use 12ga minimum to 6ga.
CHAMPwhteEK
Audio / Security / Video
Jan 18, 2009 12:55 PM
imadigitalgod
Jan 5, 2009 08:13 AM
hybrid1990crx
14
Jul 14, 2006 06:46 AM
thaiphob
Nov 1, 2002 10:37 PM
