whats the difference between component speakers
Old Jul 21, 2004 | 07:30 PM
bassisliffe's Avatar
Default whats the difference between component speakers
abd coaxial speakers, im not talking the whole component set, just the mid range speaker
im thinking if i use a seperate amp and crossover channel for the front tweeters and the mids i can make my own 'component set' as the main advantage is different crossover settings for the mids and tweeters right?
ive never had a component set but been hearing most audio heads praise them and use them religously in their set ups
only component set i ever heard were some infinitys in the back of my friends starlet, never heard one up front
Old Jul 21, 2004 | 08:38 PM
fcm's Avatar
fcm
Old Fart
Default Re: whats the difference between component speakers (bassisliffe)
If you use a 4ch amp and the amp has xovers high enough for the tweeters it will work, and if it has both upper and lower cut [band pass] for the mid , even better.
I have done a few cars useing 2 x2ch amps one for the left ch and one for the right ch , and then splitting the 2 ch of each amp to the mids., and tweets. 94
Old Jul 21, 2004 | 08:44 PM
Default Re: whats the difference between component speakers (fcm)
mid amp would be a 4 channel 600w directed tweeter amp would be a 500a2 punch should i get a 4 channel for the tweets? i will use an external crossover. coustic xm-6 with one channel foor the tweeters
Old Jul 22, 2004 | 03:08 AM
daveds50's Avatar
hummm... if i recall correctly, the Directed amp is 75 watts RMS x 4, and that Rockford Fosgate amp is 125 RMS x 2... you do not need nearly that much power going to your tweeters.
maybe 40 or 50 x 4 would be plenty. either that, or you can buy another 2 channel amp 125 RMS amp, and use the Directed for the tweets.
in this case, your cheapest way out would be passive crossovers. that way, you can just use the Directed.
when most people are talking about component speakers, they are using passive crossovers. not normally a Bi amp system like you are talking about. however, done right, a Bi amp system is the way to go.
dave ( with 2 Tri amp component systems plus subs )
Old Jul 22, 2004 | 12:22 PM
Default Re: whats the difference between component speakers (daveds50)
thanks dave, ill take all this into consideration, might just use the 500a2 for the tweets, 2 on each channel, some 8ohm tweets wouild be nice
Civic Si Kid
Audio / Security / Video
Feb 28, 2009 07:42 PM
Mark27
Dec 6, 2005 05:35 PM
low_crx87
Aug 16, 2005 01:14 PM
redman223
Jun 16, 2003 02:35 PM
D16Z6racing
Jul 24, 2002 02:00 AM
