What The Hell Could The Problem Be?
Old Apr 1, 2004 | 01:54 PM
Full Race A6's Avatar
Default What The Hell Could The Problem Be?
I bought a neon underbody kit this weekend from some big sale form a store when
I was visiting my parents a state away. Tha compnay is Ractive and its a blue kit.
I got it all wired up and when I turned it on....... only the front and left side are
lighting up. I checked all connections and there twisted and wrapped perfectly.
The ground for the transformer and the switch are intact.
Is something commonly wrong with these kit or did I just get a bad kit?
Im not gonna bring it back across state over $40 bucks but the tubes seemed
perfect when I installed it. Could it be there not getting power somehow?
Old Apr 1, 2004 | 02:31 PM
rcurley55's Avatar
New User
Default Re: What The Hell Could The Problem Be? (W O T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by W O T &raquo;</TD></TR><TR><TD CLASS="quote">all connections and there twisted and wrapped perfectly.</TD></TR></TABLE>
Please tell me you didn't simply just twist the wires together, then wrap them in electrical tape - please tell me you didn't?!!?
Swap the tubes out, put the "bad" ones where the "good" ones are. If the "bad" ones are still bad, and the good ones still good - then the tubes are broken. If the same side stays good, then it's your wiring that is suspect...which wouldn't surprise me...
Old Apr 1, 2004 | 03:24 PM
Default Re: What The Hell Could The Problem Be? (rcurley55)
Whats wrong with twisting lol? I mean I twisted it pretty good and gave about 1" from each side to be twisted.
I guess I will try switching them around, I thought maybe they would not be
getting power or something.
I never learn to solder but I though twisting would be fine.... dont see why not
Old Apr 2, 2004 | 07:45 AM
AutoXer's Avatar
No, twisting is not good, or reliable in any way. Soldering is one of the easiest things you can do; slide some shrink wrap on, heat the wire, touch solder to said wire, melt, remove heat, shrink the shrink wrap. If you're going to twist, at least use a wire cap for god sakes. Sorry, don't mean to flame, but it's just bad practice...
Old Apr 2, 2004 | 10:36 AM
doucmehu's Avatar
Default Re: What The Hell Could The Problem Be? (EX_AutoXer)
Ya, twisting would actually bo ok on inside wiring( if its done nicely) but not on outer wiring.
Old Apr 2, 2004 | 02:38 PM
EBP_SI's Avatar
Default Re: What The Hell Could The Problem Be? (doucmehu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doucmehu &raquo;</TD></TR><TR><TD CLASS="quote">Ya, twisting would actually bo ok on inside wiring( if its done nicely) but not on outer wiring.</TD></TR></TABLE>
i still think soldering or using butt connectors are the better way to go. for use in wet conditions they've also got heat shrink butt connectors where you crimp the wire in on either end and then heat it up. I've used these things before for some 10AWG wire and they are extremely strong.
twisting is the ghetto way to do thing, but then again...maybe its better the underbody kit doesnt work
Old Apr 2, 2004 | 09:36 PM
igor's Avatar
No, twisting would never be ok. Even inside a car.
sublimnal
Nov 10, 2009 02:51 PM
CRAZY-EG9
Apr 14, 2008 07:12 AM
lude98SH
Nov 11, 2007 06:38 AM
bubbajim
Feb 8, 2004 10:49 AM
ichibano
Apr 28, 2003 12:37 AM
