What fuse?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NVturbo »</TD></TR><TR><TD CLASS="quote">that pin is directly connected to the battery. you need to supply your own fuse protection when connected to that slot</TD></TR></TABLE> You are correct a fuse needs to be added to any line plugged into the free pins, [option B+], however you are incorrect, nothing on the fuse box is connected directly to the batt., in fact with the exception of the starter motor solenoid everything goes through at least a main fuse.
