what does this keep happening? help please
Old Apr 12, 2003 | 09:30 PM
DB8_TEG's Avatar
Default what does this keep happening? help please
alright it seems that everytime now that I start the car the fuse for my stereo keeps blowing (one under the hood in for the amp). I keep reaplcing it but it just keeps blowing after I start the car. I checked all my connections and there seems to be nothing, my buddy told me that it might be a bad ground but I don't see why it would be like that cause my stereo has been working fine for like 2 years til these past few days. Does anyone know what the diagnoses would be to fix this? Thanks in advance.
Modified by DB8_TEG at 7:09 AM 4/13/2003
Old Apr 12, 2003 | 09:50 PM
t0p_sh0tta's Avatar
Default Re: what does this keep happening? help please (DB8_TEG)
Check for water/condensation in the fuse holder under the hood. Recheck the ground and make sure that there is no paint where it is mounted to the body/chassis. Make sure the ring terminal, or whatevery you're using is securely attached. There has to be a sort in the system somwhere.
Old Apr 13, 2003 | 01:27 PM
DB8_TEG's Avatar
Default Re: what does this keep happening? help please (t0p_sh0tta)
well i ripped everything apart and re-wired everything and there were no wires that were pinched or anything so i know its not a grounding out problem, its the amp. When I turn the car on and the power wire is not hooked up to the amp, the fuse doesn't blow and there is power to the wire cause I used a circuit tester to try it but when I shut the car off and put the wire into the amp and turn the car back on is when i fused blows again. So if anyone has any suggestions about this you are more then welcome to help me out. I called where I bought the amp from and they says that is likely the power output and my warrenty on the amp is over.
Old Apr 13, 2003 | 02:32 PM
CereaLand's Avatar
what amp fuse are u using???
ex. if u have a 80 amp fuse.. try using a lower one, it might work
Old Apr 13, 2003 | 09:00 PM
DB8_TEG's Avatar
Default Re: what does this keep happening? help please (CereaLand)
well the Rockford just came with a 30 so I have been using that ever since and I don't want to increase the AMP rating cause I really don't want to make my amp or anything else worse.
LudeNsoL
Nov 19, 2007 08:55 AM
honda94accord
Audio / Security / Video
Aug 1, 2007 06:45 PM
jli18
18
Jul 25, 2006 07:54 PM
JDMtype Eg6
Dec 4, 2005 09:51 PM
RedDawg
Jun 10, 2001 07:45 PM
