What do you think of this box?
Old Dec 5, 2002 | 04:00 PM
420aNT's Avatar
Default Check out this fiberglass box?
This picture was taken after wet sanding. The box still needed to be buffed and polished out.
[Modified by 18gTeg, 1:01 AM 12/6/2002]
[Modified by 18gTeg, 1:18 AM 12/6/2002]
[Modified by 18gTeg, 3:00 AM 12/6/2002]
Old Dec 5, 2002 | 04:18 PM
420aNT's Avatar
Default Re: What do you think of this fiberglass box? (18gTeg)
bump
Old Dec 5, 2002 | 05:49 PM
420aNT's Avatar
ttt
Old Dec 6, 2002 | 02:45 AM
tnbigdawg's Avatar
looks sweet. you guys should write up a simple how-to on this stuff. i'd like to learn
Old Dec 6, 2002 | 08:01 AM
rcurley55's Avatar
New User
Default Re: What do you think of this fiberglass box? (tnbigdawg)
IMO, the building part is definitely not the hard part - it's actually pretty straight forward. It's the finish work...the body filler, then fillable primer, then paint and all of the extensive sanding in between...
Old Dec 6, 2002 | 08:13 AM
420aNT's Avatar
Default Re: What do you think of this fiberglass box? (rcurley55)
That correct. The sanding by hand is the time consuming part.
Old Dec 6, 2002 | 10:50 AM
loki2323's Avatar
yeah I'd really like to see a how to as far as doing the molding and everything....that box looks sick!!! good work
Old Dec 6, 2002 | 11:20 AM
Desslok's Avatar
Default Re: What do you think of this fiberglass box? (loki2323)
Hey 18gteg, do you find yourself using fiberglass for other stuff since you now how to work with it. For example, my mom asked me to look at her vacuum cleaner cause it wasn't working. The belt was fine, so I took it a apart and the housing had pieces of plastic cracked out of it. First thing that came to my mind was " I can glass this". I did and it has been working fine for a couple years now.
Old Dec 6, 2002 | 12:36 PM
420aNT's Avatar
Default Re: What do you think of this fiberglass box? (sp)
Well I can just about make anything out of fiberglass. So If I want a one off part for myself I just make it. Makes things alot easier than relying on someone else I can tell u that. If anyone needs to know anything about working with fiberglass feel free to ask, and I will try to answer you
Old Dec 6, 2002 | 01:18 PM
tnbigdawg's Avatar
yeah, i know what you guys mean....I do all my own custom bodywork on my car and sanding is the toughest part. getting it straight and smooth is very time consuming.
Old Dec 6, 2002 | 02:05 PM
rcurley55's Avatar
New User
Two questions...
Why didn't you flush mount the subs?
and
Are those subs different sizes...it may be the angle, but the one sub looks substantially larger then the other?
[Modified by rcurley55, 11:06 PM 12/6/2002]
Old Dec 6, 2002 | 06:40 PM
420aNT's Avatar
2 12's and 1 15' The subs were not countersunk since this was our first fiberglass box.
Old Dec 6, 2002 | 08:04 PM
Desslok's Avatar
Are they all sharing airspace?
Old Dec 7, 2002 | 05:09 AM
420aNT's Avatar
No there are baffles constructed on the inside out of MD and glass. The box also get screwed into another box that you cannot see. The other box is shaped from the spare tire well and sits under the false floor on the vehicle to provide adequate airspace.
Old Dec 7, 2002 | 12:52 PM
superthug's Avatar
how do u mold the fiberglass to come out like this?
and also what's the procedure of sanding and painting?
[Modified by superthug, 12:30 AM 12/8/2002]
Old Dec 7, 2002 | 01:44 PM
CoolKat's Avatar
Default Re: What do you think of this fiberglass box? (superthug)
how hard do do u thi nk it is to make this right here. i wanan make one for my hatch. its not fiberglass i dont think
Old Dec 7, 2002 | 02:13 PM
hagrid's Avatar
Default Re: What do you think of this fiberglass box? (CoolKat)
hey guys.
i'm interested in taking the trunk space..especially the space for the spare and getting a box in there. i don't want anything TOO Major. maybe just 2 subs and an amp. but is there any sites that show you a DIY? and i wanted to like put the plexi(?) glass over it so that i can still have my trunk space. thanks for an help
Old Dec 7, 2002 | 02:20 PM
Desslok's Avatar
Default Re: What do you think of this fiberglass box? (5th Gen)
hey guys.
https://honda-tech.com/zerothread?id=349096
Old Dec 7, 2002 | 06:26 PM
racerfan's Avatar
pretty nice
Old Dec 7, 2002 | 07:57 PM
dc24me's Avatar
Are the 12s and 15 all lowpass at the same xo point, or is the 12 acting as woofers (or midbass) and the 15 acting as the sub.
Are you using two different types of subwoofers because you want the lowness of a 15, but like the sound of a 12 better?
Old Dec 8, 2002 | 02:56 PM
len's Avatar
len
Default Re: Check out this fiberglass box? (18gTeg)
Sue me, but I thought boxes had four corners and is either square or rectangular...?
Old Dec 8, 2002 | 03:10 PM
hagrid's Avatar
Default Re: Check out this fiberglass box? (len)
where do you guys get the fiberglass from?
Old Dec 8, 2002 | 03:57 PM
420aNT's Avatar
Default Re: Check out this fiberglass box? (5th Gen)
Yeah I guess we should call it an enclusure instead of a box. The fiberglass we get from http://www.selectproducts.com the resin we buy locally to save on shipping and hazmat fees.
Old Dec 8, 2002 | 06:43 PM
Desslok's Avatar
Most boxes I've seen have 8 corners! OWNED!
Old Dec 8, 2002 | 07:48 PM
clm_Sol's Avatar
Default Re: Check out this fiberglass box? (sp)
LOL
The enclosure looks good, though. Have you tested out the sound yet?
