what amp for these?
Old Apr 16, 2005 | 10:05 AM
deeweezy187's Avatar
Default what amp for these?
What kind of mono amp do you guys think i should get for two of these?
http://www.woofersetc.com/prod...=3422
Old Apr 16, 2005 | 01:38 PM
surrealcivic17's Avatar
Default Re: what amp for these? (deeweezy187)
Hey that link to the subs is a little sketchy. It gives no peak wattage rating for the subs and I cant decifer whether the impedence on those babies are 2 ohms or 4 ohms. So... ill go with what info they do have. I would buy a mono amp and bridge the two subs in parallel to reduce the load. By doing so im guessing due to the specs that the amp will see a 2 ohm load. Ao buy a mono amplifier that can handle a 2 ohm load and put out at very very least 350 watts of power.
Old Apr 16, 2005 | 03:50 PM
fcm's Avatar
fcm
Old Fart
Default Re: what amp for these? (surrealcivic17)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deeweezy187 &raquo;</TD></TR><TR><TD CLASS="quote">What kind of mono amp do you guys think i should get for two of these?
http://www.woofersetc.com/prod...=3422</TD></TR></TABLE> Better to be overpowered, and without knowing the imp. of the VC, and as surrealcivic17 said, look for a mono amp stable to 2OHMs and has an output of, [ and thats were I disagree with surrealcivic17] 700watts at whatever imp. load you end up with, the best bet would be two 8OHM subs wired in parallel for a 4OHM load and a 700 watt mono block amp. 94
JDMcivicSiEG6
Audio / Security / Video
Mar 12, 2008 09:02 PM
teknoracing
30
Jun 7, 2006 03:42 PM
Dub C
Feb 7, 2006 07:15 PM
89hbcivicguy
Jun 8, 2005 12:58 PM
EVIL_AWD
13
Jul 18, 2003 12:14 PM
