want the bass inside
Old Jul 24, 2004 | 07:13 PM
bassisliffe's Avatar
Default want the bass inside
been experimenting with putting a box right in front of my sub turned sideways in the back of my jeep, it stopped alot of rattling and gave the bass a more round sound
its a sealed box firing straight into a ported box and the bass is not as loud outside as without it
im reallly exited as ive always wanted less vibration outside and when you open the doors......
Old Jul 25, 2004 | 07:42 AM
john666's Avatar
Default Re: want the bass inside (bassisliffe)
statement, question? ?
Old Jul 25, 2004 | 08:50 AM
Default Re: want the bass inside (john666)
my bad
i fired my sealed w3 into a ported box and outsidew the bass was weak but as soon as id open the doors
all the bass seemed to remain inside and hardly shake the back
this is what i want, so im thinking of experimenting more with firing subs into another box
im wondering is this is a 'bandpass' set up and if so how should i tell the box man to build one that will have the same efect?
ok i detailed everything in another thread ill just quote it
Old Jul 25, 2004 | 10:05 PM
PupaScoopa's Avatar
A bandpass enclosure will give the most gain in a limited bandwidth... but it's going to be a lot of trial and error. You car will amplify some freqencies, called cabin gain, and cancel others. This will vary on how you position the enclosure. So you'll have to play with: which frequencies to pass (by the design of the enclosure), trying it in various locations and positions in your vehicle... then either using an ear or a meter to determine if it's doing what you want or not. Typically, the lower frequencies (20 to 30hz) will travel better outside your car since the wavelengths are longer.
Old Jul 26, 2004 | 05:11 PM
Default Re: want the bass inside (PupaScoopa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PupaScoopa &raquo;</TD></TR><TR><TD CLASS="quote">A bandpass enclosure will give the most gain in a limited bandwidth... but it's going to be a lot of trial and error. You car will amplify some freqencies, called cabin gain, and cancel others. This will vary on how you position the enclosure. So you'll have to play with: which frequencies to pass (by the design of the enclosure), trying it in various locations and positions in your vehicle... then either using an ear or a meter to determine if it's doing what you want or not. Typically, the lower frequencies (20 to 30hz) will travel better outside your car since the wavelengths are longer.</TD></TR></TABLE>
thankyou
ok i want it to stay inside with the windows up, so im going to fire the port from the second box downwards, if that makes sense to you...
Old Jul 27, 2004 | 03:13 AM
Crank's Avatar
dynamat is your friend
Old Jul 27, 2004 | 06:11 AM
spark plugs.
Guest
Posts: n/a
Default Re: want the bass inside (Crank)
i dunno if i'm gathering this correct, but you WANT noise and rattling outside the car?! if you ask me, the set up you're aiming for sounds sloppy and misdirected. it sounds like you just want the waves to bounce around a lot. that's asking for a lot of distortion. you might get hear a lot more noise outside and it might appear louder because of all the noise movement and rattling, but ultimately, you're gonna have a lot of conflicting waves bouncing around and you'll lose sound quality. sound is best when it has a nice neat path to follow. think about one fat kid stomping his feet inside and a bunch of skinny kids stomping inside but their footsteps milliseconds out of cadence.
Old Jul 27, 2004 | 09:01 PM
Default Re: want the bass inside (spark plugs.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spark plugs. &raquo;</TD></TR><TR><TD CLASS="quote">i dunno if i'm gathering this correct</TD></TR></TABLE>
you didn't its the total opposite dude, i want all the bass insiode with no rattling and no 'shaking' of the back so i cn be heard a mile away even with the windows up
i want to crack the window and shock people with bass
Old Jul 28, 2004 | 02:33 PM
hybridzOr's Avatar
keep y0 *** at the termpro forums LOL
Old Jul 28, 2004 | 04:15 PM
Default Re: (Hybrid Racer.)
hehe
powerdbygarrett
Audio / Security / Video
Nov 20, 2006 11:53 AM
Tonyl507
Aug 14, 2006 08:26 PM
civic_speed99
Aug 16, 2004 07:05 PM
loki2323
Nov 10, 2003 12:06 AM
GoLowDrew
Jul 28, 2001 09:52 AM
