Viper Alarm HELP
Have had no problems with my alarm until this morning. Not sure if it was a button i pressed or what. Model EZSDEI478. Only a couple things I noticed were different. Theres no more alarm sound. The lights still blink like they should but theres no sound. And the blue LED stays a solid blue instead of blinking. Mabye its in valet mode and i dont know how to take it out? I checked all the fuses under the dash and all were ok. The knock sensor was in working order. When i locked and unlock the car it works on the remote and i hear the relay clicking over.
Any Ideas appreciated!
Thanks!
-Steve
Thanks!
-Steve
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Its in valet mode. open a door. passenger so your not in the street. Press lock,unlock,lock,unlock,lock. This should cure your problem. Bigger problem is that if you can look right under the dash and check the fuse on the alarm. Your alarm is in no shape to protect your car.
Ive been having a similar problem with my viper alarm as well.The screen dosent acknowledge when the car is locked or unlocked and the auto start will run for like 4 seconds then shut off and keep trying to turn over.Ive thrown codes at it with the doo open and it will be back to normal, but soon after it will start to do it again.Does anyone know if its my pager or wiring or....help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrx-killer-Sti eater »</TD></TR><TR><TD CLASS="quote">Its in valet mode. open a door. passenger so your not in the street. Press lock,unlock,lock,unlock,lock</TD></TR></TABLE>
Yess!!!! Worked! Open up door and tried the way you did.. didnt work.. so i got pissed and kept pressing them back n forth and the remote went beep beep beep and now it work!!! yessss
i need help too my problem is similar and i dno't know what model it is but i have a viper alarm and one day it stoped beepin when i pushed the lock button on the alarm... i don't think its settin either cause i locked my doors with the button and then went around the passenger side and unlocked that door with the key and opened it and the alarm didn't go off... so i don't know what happend could some plz help!
it blinks. i have an old school remote (haven't upgraded yet) so all i have is the one green led and it blinks like it always has
*edit*
i fixed it!! i had found the valet button and pressed it by accident!
Modified by FATKID87 at 3:35 PM 12/11/2006
*edit*
i got it to work now. who ever runs into this problem you need to take it off of valet mode.----> press LOCK/UNLOCK button once, followed by the AUX button, then LOCK/UNLOCK. give it a sec or two and there it is back to normal.
Paul
