Viper 350hv Install help
Old Mar 30, 2005 | 08:12 PM
projectPSI's Avatar
Default Viper 350hv Install help
have my viper 350hv installed. Everything works fine. I want to add a switch so my alarm goes off when someone pops the hood. which wires do i hook up from the switch to teh alarm to get this to work.
Anyhelp will be greatly appreciated.
Thanx in advance
Old Mar 30, 2005 | 09:14 PM
bossman032's Avatar
Default Re: Viper 350hv Install help (projectPSI)
it should have a Negative trigger run that wire to a hood pin.
Old Mar 31, 2005 | 06:45 AM
projectPSI's Avatar
which color wire is it? i dont have the install booklet so i dont know which wire is which and i cant find one online. Anyone know where to find one or just let me know what color it is.
Thanx
Old Mar 31, 2005 | 11:03 AM
Demented's Avatar
Default Re: (projectPSI)
the blue wire is the one you are going to use
its an instant trigger (neg.)
Old Mar 31, 2005 | 03:17 PM
projectPSI's Avatar
so what do you hook the switch too? Do i make a loop with the blue and put the switch in the middle r how does this work.
Old Apr 1, 2005 | 06:28 PM
taltares's Avatar
dark blue wire it is called instant trigger wire.
Old Apr 5, 2005 | 12:20 PM
Richard Noggin's Avatar
From: Good luck to this industry, you're gonna need it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectPSI &raquo;</TD></TR><TR><TD CLASS="quote">so what do you hook the switch too? Do i make a loop with the blue and put the switch in the middle r how does this work. </TD></TR></TABLE>
You need a "hood pin switch" they typically go on the rad support...when you get one you'll understand what to do with it.
-Chris
hellajdm333
16
Feb 20, 2010 02:35 AM
Jdmglenn
Audio / Security / Video
21
Oct 29, 2006 09:40 AM
EnSAn
24
Aug 10, 2006 08:36 AM
.jacob
Dec 6, 2003 09:50 AM
Remmy
Feb 3, 2003 06:55 AM
