using power cable as ground?
Old Oct 4, 2004 | 06:35 PM
devilpuppy's Avatar
Default using power cable as ground?
i have extra 8 gauge power cable (its not wrapped red like my other one, this one is wrapped in black)
but i need to make my ground connection longer, so it is okay to use that extra cable i have?
cuz i figured its all the same cables, just the colours denote the uses
so basically, is it safe to use my extra power calbe for grounding?
Old Oct 4, 2004 | 07:27 PM
archmage's Avatar
Default Re: using power cable as ground? (devilpuppy)
wire = wire, you're correct.
That cable is fine.
Old Oct 4, 2004 | 10:17 PM
SpoonFedHatch's Avatar
just keep in mind that the ground should be a short commute from the connection to the physical ground...
just keep it as short as possible (without major complications) with that 8guage and you'll be fine
Audio / Security / Video
Feb 23, 2013 09:37 PM
rnutter
Honda CR-V & Element
Jan 4, 2011 07:51 PM
imadigitalgod
Jun 3, 2008 10:16 PM
kroze
Sep 22, 2007 02:31 PM
4DoorLS
Oct 7, 2002 04:09 PM
