'unbreakable autolock'
Old May 11, 2001 | 11:50 PM
ianferrell's Avatar
New User
Default 'unbreakable autolock'
Does anyone have any experience with these doods? They seem to have a pretty good idea, and it seems to work pretty well. I'm just wondering if anyone has heard any bad things about them. The only real weekness I could see is if you were to pry the side of the fork off as it appears to only be connected by two spot welds, I'm thinking that with a crowbar or some other tool you might be able to pull the arm off and simply kick it out of the way. If it is however as strong as the claim it is, it could easily be worth $60. their website: http://www.unbrakeable.com/
Old May 14, 2001 | 07:04 AM
Lewd Lude's Avatar
Default Re: 'unbreakable autolock' (ianferrell)
Believe me, if something can be put on, it CAN be taken off...it is only a deterent, undriveable, get lost...all you need to do is remove the pedal....once they do this you can still use the metal lever instead of a pedal, get the car away and reweld the pedal back on....granted not every thief is going to such an extreme, but the ones that wont are the same ones that would be detered by the cheapest anti theft device....
Old May 15, 2001 | 10:01 AM
BlackAckeR's Avatar
Default Re: 'unbreakable autolock' (Lewd Lude)
I've got one... For the price, why not use it; every bit that slows the thiefs down helps, but nothing is fullproof. If it is half as hard to get off without the key as it is putting the thing on, it should frustrate the most determined crook...
PrettyMuchBoned
Apr 24, 2014 07:20 AM
EFinawesomeman
Paint and Body
Jun 22, 2009 01:17 PM
avaldez
Welding / Fabrication
12
Jun 11, 2009 08:33 AM
Andrew Marquis
Apr 29, 2006 05:51 PM
ALF
Jul 24, 2001 01:47 PM
