Tweeter install
The car I recently purchased came withe a door panel with a tweeter hole:
I trashed it without hesitation...
Thanks for starting this thread as I am also thinking about better speakers setup.
Did anyone see or considered tweeter mounted on a pillar, where they are usually mounted? I know that there is not enough room between the pillar and the trim piece to make the speaker assembly sit flush, but with a low profile tweeter it wouldn't probably look worse than those ridiculous nitro gauges sometimes mounted there... Any opinion on that?
What about even higher location - somewhere by the visors? Too high?
I hope I am not thread-jacking.
Eh, I only placed then there because I wanted to cover up the hold from my manual window regulator. I'll eventually move them after I find a better piece to fill the hole.
Use a good ole fashioned hole saw. You can pick one up at any local parts store. Ace hardware, lowes, home depot. Mark where you want to put the tweeters, with the door panel off so you can make sure there is room behind the panel for the tweeter. You want to keep the tweeter with 18 inches of the door speaker. When you are about the make the hole have the drill going in reverse, having it in forward will grab the fabric on the door panel and rip it to ****. So drilling the hole in reverse will take a little bit longer but will have the install look ten times better and save your door panel. Now there are other ways you can install them, there is flush mount(looks the best) and surface mount. The installation of doing flush mount is actually pretty simple. Hope this helps you out
Hole saw would prob. be the easiest, you know the one you attach to your drill. You should also considering taping off the area to prevent vinyl damage. Or if that doesn't seem to be clean enough (I wouldn't know as I have never done it - but I like to tinker) I would prob. draw a circle first, then cut the vinyl out with something like exacto knife and drill/cut through hard plastic with just about anything.
In case you did not know the upper section of door panel (the soft one) is composed of three layers: hard plastic backing - maybe 1/8" thick, thin layer of foam, and a vinyl covering it all.
why dont you just put the tweeters on the dash with the little tweeter pod things that usually come with just about all component sets. this way you dont need to worry about running more wires through your door, and you can most likely achieve the best sound by bouncing the tweeters off the glass? im going to install mine this way
Here is another creative yet off the wall location for those with powered mirrors and no mirrors at all ;-) mirror trim pieces! Something like this:
http://cgi.ebay.com/ebaymotors/96-97...#ht_3110wt_981
anyone ever make a fiberglass cover where the side mirror adjusters are? that way youre not messing up door panels...
maybe difficult to get around not having mirror adjustment arms... but id give up being able to adjust them from inside and just have someone adjust them once by pushing on the mirror directly.
i REALLY wouldnt ever want to cut a hole in my door panels.
i haven't made a fiberglass cover for mine, yet, but i have my tweeters attached to the mirror cover. works fine for me since i installed working sedan power mirrors on my hatch.
