Turn Sigs aren't Working
Old Mar 4, 2004 | 08:57 AM
FasteR1's Avatar
Default Turn Sigs aren't Working
I just bought a '99 Civic SI (Black). Well my turn signals don't work (Front and back). It doesn't even blink on the dashboard. Somebody at the auto parts store told me it could be due to the previous owner using it to power his stereo. Well I need help figuring out if that is the case or what else could be contributing to this. (I have already changed the fuse so that's out of the question.)
FasteR1
Old Mar 4, 2004 | 11:02 AM
greebler's Avatar
Default Re: Turn Sigs aren't Working (FasteR1)
Check the emergency hazards switch, if this is unplugged or broken. The turn signals will not work at all, neither outside or on the cluster.
"Somebody at the auto parts store told me it could be due to the previous owner using it to power his stereo."
This guy is a moron......
Old Mar 4, 2004 | 01:03 PM
vividsport's Avatar
I would check the combination switch in the column, since it is the central control point, and with nothing working that is a good place to start. If that doesn't work, email me audiobird@hotmail.com and I can get you the troubleshooting flowchart.
Old Mar 4, 2004 | 03:20 PM
rjr162's Avatar
Default Re: Turn Sigs aren't Working (vividsport)
I would also check the flasher unit under the dash in the fuse box (IIRC that's where they are located).
It's quite possible either that unit is toast, or a fuse its self may be bad.
Old Mar 5, 2004 | 11:51 AM
greebler's Avatar
Default Re: Turn Sigs aren't Working (rjr162)
He checked the fuse!
Im telling you, its most likely the hazard button. Personal experience..............
Old Mar 5, 2004 | 09:49 PM
shipsaeki's Avatar
Default Re: Turn Sigs aren't Working (greebler)
check the hazard. if it works, its most likely the flasher unit. go get another one for about 7 bucks.
Old Mar 8, 2004 | 10:14 AM
FasteR1's Avatar
Default Re: Turn Sigs aren't Working (shipsaeki)
I checked the hazards and they aren't working as well. I'll try the the flasher thingy. (i'm not all the carliterate - i ride motorcycles) But thankx for all your help!
FasteR1
slammed4dreg
26
Nov 16, 2014 04:24 PM
egboy94
Feb 26, 2011 05:52 AM
92eg_b16
Oct 19, 2008 12:52 AM
kwalzy
Mar 19, 2008 12:12 PM
FasteR1
Audio / Security / Video
Mar 15, 2004 07:25 PM
