Transmitter range
Old Oct 24, 2005 | 10:52 AM
MLD211's Avatar
Default Transmitter range
Well I was bored so I was thinkin we could post some tips or techniques for maximizing transmitter range. Anybody have any tips or tricks they use?
Old Oct 24, 2005 | 11:09 AM
B18C_EJ8's Avatar
Put the remote to your chin and press the button...
Old Oct 24, 2005 | 11:12 AM
B18C_EJ8's Avatar
If I'm doing a one-way starter, I keep the excess antenna wire in the headliner; meaning that I run the wire up the a pillar, then over as far as I can, then back to the antenna. That seems to help on the Avitals.
Also, your range is significantly affected by your ground. Good ground in the kick panel usually gets more range as opposed to a secondary ground made on the dash support somewhere...
Old Oct 24, 2005 | 11:22 AM
MLD211's Avatar
I agree coiling up extra antenna wire and shoving it under the dash is deffinatly not good. I also believe a good ground will make any alarm or remote start have much better range and less problems in general.
db8int3gra
Audio / Security / Video
Feb 16, 2009 04:46 PM
OneFire
May 13, 2005 07:11 PM
spunky424
Mar 2, 2004 08:14 AM
Catera
Jan 25, 2004 11:40 PM
ken
Nov 1, 2001 03:58 PM
