Tips for replacement of head unit in 2000 Civic?
Old May 26, 2004 | 05:12 PM
JoshuaVTEC's Avatar
Default Tips for replacement of head unit in 2000 Civic?
Tomorrow my new Alpine head unit arrives, it's the CDA-9831
Anyone have any special tips for replacement of the stock head unit? I'm guessing the center console is just clipped on, and will pop off with a little bit of pressure?
Old May 26, 2004 | 09:30 PM
ShaunRR's Avatar
HT White Ops
Community Builder
Default Re: Tips for replacement of head unit in 2000 Civic? (JoshuaVTEC)
No it doesn't just pop off. You need to remove the panel below it and remove the brass screws holding to the steel frame structure behind.
I can't tell you how many screwed up dashes I have seen on civics from the EKs on up to the new ones, because people follow your same train of thought.
BTW, the bottom panel doesn't just pop off either. Look for the screws.
Old May 27, 2004 | 04:55 AM
JoshuaVTEC's Avatar
Default Re: Tips for replacement of head unit in 2000 Civic? (rochesterricer)
...which is why I asked
Old May 27, 2004 | 12:09 PM
ShaunRR's Avatar
HT White Ops
Community Builder
I wasn't trying to be an ***, sorry if I came off that way.
Old May 27, 2004 | 12:46 PM
EBP_SI's Avatar
my suggestion is to buy the oem pieces to mount it down by the cup holder for a few reasons. It's much better as far as a theft deterrent because when you take the face off you can just pop up the cover and its hidden plus you've still got the original play in its spot. the second reason is i found with my 7995, it didn't matter what time of the day it was or what direction i was driving in, i would get some horrible glare off the face when it was up higher.
2DoorBandit
Oct 23, 2006 05:23 AM
93allmotorcoupe
Audio / Security / Video
Mar 17, 2006 08:43 AM
texasnick
Jan 25, 2005 11:06 PM
Inaniac
Feb 25, 2004 03:35 PM
bennihana
Jan 20, 2004 10:54 AM
