Testing Blown Subs
Old Feb 8, 2004 | 08:53 PM
fe519's Avatar
Default Testing Blown Subs
hey everyone. yesterday when i was driving, i noticed that my sub sounded a little weird. Then I pulled over and checked and it sounded as if it has blown (flapping noise). I wasnt playing the music loud or anything... I guess it just happened. I pulled the sub ( 2 ohm kicker solo-baric) out of the box and tested resistance on the + and - terminals and it did register at 1.9 ohms. Im not sure if that is a way to test if the sub has blown but everything seems to be ok. The wire that comes out of the magnet to the terminals on the sub seems perfect and untouched. Can someone help me out? I appreciate the help.
Old Feb 8, 2004 | 09:52 PM
..::91TEG-G2::..'s Avatar
Default Re: Testing Blown Subs (fe519)
could be blown coil.. cuz i know thoes subs have a rubber surround and a hard plastic "woofer" section.. so it'd be hard to blow them.. the only thing i could think is the voice coil/coil is blown..
Old Feb 12, 2004 | 05:05 PM
fe519's Avatar
Default Re: Testing Blown Subs (..::91TEG-G2::..)
is there anyway i can fix the coil?
Old Feb 12, 2004 | 05:12 PM
GSteg's Avatar
does it make a nasty scratching noise?
Old Feb 12, 2004 | 09:50 PM
turbod16y8's Avatar
Default Re: (GSteg)
try pushing the cone in. if it starts making crunch noise then the voice coil is gone.
Old Feb 13, 2004 | 08:25 AM
fe519's Avatar
Default Re: (turbod16y8)
the sub makes a flapping noise... only at certain bass. it doesnt matter how high the volume i turn up... it doesnt play that frequency. I dont know much about fixing subs and never fixed one so maybe someone can educate me. I pushed the cone in and everything seems normal. Any ideas?
Old Feb 15, 2004 | 12:46 AM
turbod16y8's Avatar
Default Re: (fe519)
mine made this sound when the positive and negative were reverse. check taht
Old Feb 15, 2004 | 09:01 PM
fe519's Avatar
i checked the + and - terminals... the sub was working the day before and nobody touched it
Old Feb 16, 2004 | 05:26 AM
stumbler's Avatar
Default Re: (fe519)
you could use a dmm and test the resistance
dallasyoung
Audio / Security / Video
16
Sep 3, 2017 10:20 AM
InfamousCivic
May 29, 2007 06:58 PM
lemongreenhatch
Jun 5, 2005 09:10 AM
Supta
Nov 18, 2004 10:24 PM
lotas
Aug 30, 2004 10:47 PM
