tachometer wiring
Hello all
First post of what will probably be of many as im not the greatest when it comes to hondas
Currently have it all wired in bar the problem below
Can anyone tell me which wire i use from the distrubutor or from the normal clocks to receive the rpm signal for this
http://www.4wheelparts.com/Cobalt-Sh...6&t_pn=AMG6299
Here is the wiring diagram for it
http://www.autometer.com/productPDF/1244.pdf
engine is a b16a2 if that is any help
thanks for any info u can give
Mikey
Mikey
^^ that would be a big help.
Some vehicles run a cable drive tach, the tach in the cluster generates the VSS pulse for the ECU, others have a electronic VSS sending unit in the tranny and a electronic tach. Either way, wiring will be different.
clgarner
Apr 2, 2008 05:39 PM
SOHC_MShue
Aug 10, 2005 02:07 PM
94
