switches keep burning
my wires caught fire so i ran a wire from the air conditioning fan and compressor to a switch inside and then to the battery
the switch gets hella hot and it blew tonight, how can i wire a switch for the ac safely? maybe a heavy duty switch? maybe a fuse that would blow instead of the switch?
help
help
What originally caught on fire, just ac wires, engine fire, electrical? Is this the only thing that needs to be re-wired? What type and fuse rating is the switch that you are using?
You are probably using too small of a switch. You can use a relay, but I would recommend 1 for the fan and 1 for the compressor. You should also be running at least 12 gauge wiring for it.
Promisering
Oct 10, 2018 04:40 PM
tub_sephiroth
May 9, 2007 07:35 PM
