Subwoofer system makes engine noise
Old Oct 17, 2007 | 07:05 PM
Extreez's Avatar
Default Subwoofer system makes engine noise
Connected my subs today, found that the subs makes a quiet bassey voice with the engine and a low pitch sound with the cars drivability gets annoying what can solve this problem ?
Old Oct 17, 2007 | 07:16 PM
thatasiankidtony's Avatar
Default Re: Subwoofer system makes engine noise (Extreez)
Where did you ground your amp? Make sure it's good.
Did you run your RCA's with the power? If so you should separate them and run them on different sides.
Old Oct 17, 2007 | 08:52 PM
Extreez's Avatar
Default Re: Subwoofer system makes engine noise (thatasiankidtony)
grouded them on the frame drilled hole and screwed in, below exhaust. Both wires heading seprate ways.
Old Oct 18, 2007 | 12:40 PM
NVturbo's Avatar
O.G. triple O.G.
You may have some audible interference if you use cheap RCA cables. You do not have to have expensive brands, just as long as they are decent.
Old Oct 18, 2007 | 01:03 PM
taltares's Avatar
If u have some cheap rca's take a piece of wire and stick it in one of the rca and then ground it.
Old Oct 18, 2007 | 04:54 PM
suspendedHatch's Avatar
Default Re: Subwoofer system makes engine noise (taltares)
Could be a crappy amp also.
T off from the stereo ground with an 18 gauge wire and ground it to the same point as the amp ground or terminal.
a.wax
Audio / Security / Video
Sep 4, 2007 05:37 AM
dirtycolombian
May 6, 2007 03:23 PM
teamvirus
Oct 25, 2006 03:39 AM
Accord1959
Dec 3, 2004 07:14 AM
Integra99GSR
10
Sep 10, 2003 11:56 PM
