subwoofer enclosure help
Old Mar 14, 2005 | 09:33 PM
idriveadelsol7's Avatar
Default subwoofer enclosure help
just a quick question. i drive a del sol and i want to shorten the height of the box so:
if i subtract '1'inch off of height, does this mean i must add '1'inch to the width or '1' inch to depth. thanks
Modified by deL soL 7 at 12:07 AM 3/15/2005
Old Mar 14, 2005 | 11:11 PM
KamoteMan's Avatar
Default Re: subwoofer enclosure help (deLsoL7)
yup
Old Mar 15, 2005 | 12:47 AM
Default Re: subwoofer enclosure help (teamKamote)
cool thanks. now where do i pick up materials? do they sell MDF woord at home depot? not to sure on what else i need.
Old Mar 15, 2005 | 05:09 AM
MechaniZm's Avatar
Technically speaking, yes you will have to increase other dimensions accordingly..however I'll be honest with you, and tell you that you're probably not going to notice any difference in the sound between the box that's 1" taller and the one with 1" cut off. If it's a sealed box, just stuff it with dacron polyfill and be done with it. You're probably going to cause more problems than anything by modifying the other dimensions. This information applies primarily to a sealed type enclosure, because if it happens to be ported, the volume change will raise the tuning frequency of the box, possibly to a point where it's undesirable.
Old Mar 15, 2005 | 08:37 AM
fcm's Avatar
fcm
Old Fart
Default Re: subwoofer enclosure help (MechaniZm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MechaniZm &raquo;</TD></TR><TR><TD CLASS="quote">Technically speaking, yes you will have to increase other dimensions accordingly..however I'll be honest with you, and tell you that you're probably not going to notice any difference in the sound between the box that's 1" taller and the one with 1" cut off. If it's a sealed box, just stuff it with dacron polyfill and be done with it. You're probably going to cause more problems than anything by modifying the other dimensions. This information applies primarily to a sealed type enclosure, because if it happens to be ported, the volume change will raise the tuning frequency of the box, possibly to a point where it's undesirable.</TD></TR></TABLE>I will agree......... mostly, it all depends on the surface area you take the 1" off , if the "top" of the box is say, 3"x30" thats about 90 cu in, and 90 cu in in a 1.5 cu ft box 2592 cu in is way less then 10% so no real diff. but then again if the top of box is 12"x30" thats 360 cu in and that could make a diff.
And yes, you can get MDF at most building supply stores HomeDepot will sell 1/2 sheets and make 2 or 3 cuts for free
So deLsoL7 ..... it makes no diff. how you get the volume, just that you get it, the way I do it, I look at the fixed measurement first, and that is normaly how wide can it be "W" and as your hight is limited next would be "H" so WxH = sq in, divide that into the gross volume and you will get "D" depth, don''t forget use inside measurements, also you need to take into account the depth of the speaker, [so it will fit into box] a 3" deep box just ain't going to make it with a 4" deep speaker so do this, your hight is fixed "H" and your depth is fixed at no less then 4" and you have an angle on the box, 4" on the and 6" on the bottom 4+6= 10 divide by 2 = 5" "D" so HxD divided into gross volume will give you width "W". easy as cake 94
Old Mar 15, 2005 | 06:20 PM
jdMaDDiCT666's Avatar
YEA GO TO HOMEDEPOT AND GET THEY SHOULD HAVE IT AND YES YOU MUST HAD THAT TO THE WIDTH OR IT WILL CHANGE THE SOUND
Old Mar 15, 2005 | 09:44 PM
MechaniZm's Avatar
Default Re: (jdMaDDiCT666)
OMG WTF LOL DA CHANGE IN SOUND WIL HARDLY B NOTICABLA AND U CAN G3T MDF AT ANY BUILDNG CENTAR!!!1!1!LOL
Old Mar 16, 2005 | 10:39 AM
fcm's Avatar
fcm
Old Fart
Default Re: (MechaniZm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MechaniZm &raquo;</TD></TR><TR><TD CLASS="quote">OMG WTF LOL DA CHANGE IN SOUND WIL HARDLY B NOTICABLA AND U CAN G3T MDF AT ANY BUILDNG CENTAR!!!1!1!LOL </TD></TR></TABLE> Loose the CAPs nobody likes it when you yell 94
Old Mar 16, 2005 | 12:28 PM
MechaniZm's Avatar
Default Re: (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> Loose the CAPs nobody likes it when you yell 94</TD></TR></TABLE>
Umm, that was in respose to jdMaDDiCT666's post...not my style
Old Mar 16, 2005 | 09:58 PM
sparkz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deLsoL7 &raquo;</TD></TR><TR><TD CLASS="quote">cool thanks. now where do i pick up materials? do they sell MDF woord at home depot? not to sure on what else i need.</TD></TR></TABLE>
Do you plan on making the box yourself? I hope you have a table sawbecause you will want to make the cleanest cuts of wood.
Old Mar 17, 2005 | 11:27 AM
parasonic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MechaniZm &raquo;</TD></TR><TR><TD CLASS="quote">OMG WTF LOL DA CHANGE IN SOUND WIL HARDLY B NOTICABLA AND U CAN G3T MDF AT ANY BUILDNG CENTAR!!!1!1!LOL </TD></TR></TABLE>Go entertain yourself. http://www.roflcopter.com/forum/index.php
Old Mar 20, 2005 | 10:43 PM
KamoteMan's Avatar
Default Re: subwoofer enclosure help (unrefined7)
what size of your sub?
Old Mar 21, 2005 | 05:48 AM
1' 12 inch
teamaudiobox
14
Nov 5, 2011 05:11 PM
DelSolMarine
Audio / Security / Video
13
May 1, 2006 07:06 AM
imlachg1
10
Mar 21, 2004 05:21 PM
Trooper
Nov 11, 2002 05:58 AM
