Subs poping
Old Jul 5, 2004 | 09:54 PM
skrewdriver88's Avatar
Default Subs poping
This just started today when i got in my car and turned it on my subs poped and then it is fine and still plays everything ok. it also does it when i turn my car off. What could the problem be? I already checked all of my fuses and they are good. By the way i have 2 10's audiobahn with a 1400 watt majestic amp.
TIA
Old Jul 5, 2004 | 10:04 PM
CrOmEdOmEcHaMbEr's Avatar
Default Re: Subs poping (skrewdriver88)
Did you check your grounds??
Yesterday I reinstalled my system (10w7 & 5001) after finishing up some custom work and didn't realize that I had a loose ground. The sub only popped when I turned it on and off...
Old Jul 5, 2004 | 11:53 PM
MCall's Avatar
read the audio faqs
ur answer is there
to fix the problem with turning it off and it popping if ur amp has the option set the on/off delay time
ie... once ur car is started it takes a second or two befor ethe amp turns off... and visa versa when turning car off
but read the faq anyways
Old Jul 6, 2004 | 05:46 AM
Default Re: (MCall)
Thanks i think it might be my ground because it came loose one other time also.
Old Jul 6, 2004 | 11:51 AM
Pyros2k's Avatar
see if your subs pop if you just turn the head unit off...if it does the same thing as with the ingnition, you've got a problem with your ground or your amp...if it doesn't pop...your amp is turning off before your head unit...you'll need to look into getting a turn on/off pop eliminator...which should be available from most any audio shop.
Old Jul 6, 2004 | 01:23 PM
Default Re: Subs poping (Pyros2k)
How much is it for a pop eliminator?
Old Jul 8, 2004 | 09:49 PM
anybody?
Old Jul 8, 2004 | 09:59 PM
TnTWRX's Avatar
Stinger Pop-on eliminator $16.95
http://search.cardomain.com/cg...+pop+
Stinger Pop-off eliminator $16.95
Old Jul 8, 2004 | 11:01 PM
Default Re: Subs poping (TnTWRX)
K thanks but do they make one were it works when it turns on and off in one?
THANKS
Old Jul 9, 2004 | 04:54 AM
Where do i connect and mount the pop eliminator at in my car?
TIA
Old Jul 9, 2004 | 12:08 PM
Bump
Old Jul 10, 2004 | 08:58 PM
Anybody HELP
Old Jul 12, 2004 | 01:15 AM
COME on guys
LSej1
Audio / Security / Video
13
Oct 6, 2011 05:32 AM
sz9182
Nov 2, 2009 03:45 PM
SiBuddy00
Apr 15, 2009 05:02 PM
ef_88_hatch
13
Sep 13, 2008 12:53 PM
IloveNewt
10
Mar 21, 2003 10:23 AM
