Subs in back seat
Old Oct 6, 2005 | 06:08 AM
H22a T13's Avatar
Default Subs in back seat
I am about to install some new seats and 6-point harness, so i am thinking of removing the rear seat compleatly. Would it be possible to mount subs in the rear sheat metal with the heads facing in, will this metal be stron enough to hold the subs and not rattle excesivly.
Old Oct 6, 2005 | 06:10 AM
Slain's Avatar
you would need to bolt it down real good otherwise it will turn into a deadly hurling object in the case you need to brake real fast.
Old Oct 8, 2005 | 01:51 PM
CooBlueDAB's Avatar
Default Re: (Slain)
I thought of doing that before, but I think using MDF wood would be better for that as long as it is braced... and removable.. however, you could use sheet metal, make a proper small box in the lower middle or wherever, cut to size a hole in the sheet metal, and attach...
Old Oct 9, 2005 | 07:15 AM
B18C_EJ8's Avatar
Need to use MDF... Sheet metal will resonate like crazy and sound like crap...
Old Oct 9, 2005 | 11:07 AM
fcm's Avatar
fcm
Old Fart
Default Re: Subs in back seat (H22a T13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22a T13 &raquo;</TD></TR><TR><TD CLASS="quote">I am about to install some new seats and 6-point harness, so i am thinking of removing the rear seat compleatly. Would it be possible to mount subs in the rear sheat metal with the heads facing in, will this metal be stron enough to hold the subs and not rattle excesivly.</TD></TR></TABLE> Not sure I understand what you mean by "rear sheet metal" and "heads facing in", that said, B18C_EJ8 is correct....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">Need to use MDF... Sheet metal will resonate like crazy and sound like crap...</TD></TR></TABLE> Your subs need to be in a proper box, at the very least they need to be mounted to a MDF baffle, and unless the subs are "free air" the have to be in a cabinet specific to that sub/s, even a "free air" sub needs a cabinet, its just a big one, trunk of car, and even then the baffle needs to be MDF for there to be any decent sub bass, sheet metal just isn't going to work.
But if you are removing the rear seat anyway, why not build a MDF and fiberglass box and design it to fit where the rear seat was and use the seat belt bolts to mount it, it would be rock solid, and sound great, [assuming it's built properly] 94
sirlaughsalot
Aug 22, 2009 11:29 AM
RacerGirl629
Honda Fit
Jun 24, 2007 07:06 PM
YoungKadafi
Dec 4, 2006 03:20 PM
94civicEX
Mar 14, 2005 06:14 PM
CrazyModGSR
May 5, 2004 12:42 PM
