sub wiring Q
Old Jul 19, 2004 | 03:50 PM
RallyRedGT-V6's Avatar
Default sub wiring Q
I have a 750w mono amp, 2 ohm stable...picking up a set of alpine type r's...i am confused as to whether i should get the 4 ohm or 2 ohm ones...my gut instinct is telling me to get the 4's
can someone confirm/deny this for me?
Old Jul 19, 2004 | 05:33 PM
Eric R's Avatar
Default Re: sub wiring Q (96integra)
Well, you'll do right if you follow your gut instinct. Just make sure they're 4ohm SVC and install 2.
Old Jul 19, 2004 | 10:07 PM
ShaunRR's Avatar
HT White Ops
Community Builder
Default Re: sub wiring Q (Eric's R)
The Type R's are only available in DVC.
To achieve a nominal load of 2ohms with 2 subs, you will need the dual 2ohm versions. You will simply wire the coils in series and the subs in parallel. Simple.
bryan0
Audio / Security / Video
Sep 10, 2008 10:11 AM
1bar
Dec 18, 2005 08:06 AM
crxgator
Jul 2, 2005 10:26 AM
XViEtBoiX
Aug 8, 2004 07:47 AM
rasta420
May 11, 2002 11:28 PM
