Sub signals - high and low
Old Jul 19, 2001 | 02:43 PM
GoLowDrew's Avatar
Old Member
25 Year Member
Default Sub signals - high and low
On the feed to my sub, I turned the low bypass filter on to let only the only the lows in.
Question: Does the highs do anything in a sub at all? or does it just get in the way?
I don't hear the difference. But do hear a difference if I allow only highs in to the sub.
The goal is quality, instead of bone pounding base.
Old Jul 19, 2001 | 06:18 PM
G's Avatar
G
Default Re: Sub signals - high and low (GoLowDrew)
Well, the frequencies outside of the subs' range do get in the way. They can actually be harmful to the sub and the sound. Playing the frequencies above the sub's reccomended range will heat the coil due to the inability of the cone to move accordingly. Those same frequencies will also produce a humming because of the same problem. For a good clean sound, it is best to match speaker specs with the enclosure and crossover points. Sealed seems to be the enclosure of choice when it comes to quality sound systems....... Although, I prefer a ported enclosure, when it comes to auto sound systems (loud and clear).......
Old Jul 24, 2001 | 04:20 AM
DuNkiN's Avatar
New User
that actually is quality, i think your getting everything confused. if your speakers can be that loud its good, it just depends on how much gain you put on it.
Putting high freq is bad for subs.
Old Jul 27, 2001 | 04:15 AM
kg's Avatar
kg
also, your amp is less efficient when you are letting the highs in. this is because it is trying to amplify the complete frequency band rather than just the lower frequencies that you really want.
as for [(quality) != (bone pounding base)], i suppose it depends on what kind of music you listen to.
patrickstar
Audio / Security / Video
12
Feb 19, 2009 04:10 AM
imadigitalgod
Oct 2, 2007 08:02 AM
Savv
Sep 28, 2004 03:11 PM
CJWilson
21
Mar 25, 2004 11:19 PM
ck279
May 27, 2002 11:05 AM
