sub question
Old May 10, 2004 | 10:11 AM
RiCE On IcE 2's Avatar
Default sub question
what would cause a sub to consistantly vibrate. My sub seems to be dogin that once in a while.. it jsut consistantly sends out a low bass note even when the deck is turned down. could it be ground thats causing it?
Old May 10, 2004 | 04:19 PM
pain's Avatar
Default Re: sub question (RiCE On IcE 2)
ok man ill try to help.. check your wiring first.. make sue pos and neg are ok and then check your rca's see if that helps..
Old May 10, 2004 | 04:49 PM
integranation's Avatar
check your RCAs. They could be touching some metal and sending feedback in the signal to the amp. Making sure you have a good ground connection wouldn't hurt either, but I have had the RCA thing happen before so it would be a good place to start.
Old May 10, 2004 | 04:53 PM
nver2's Avatar
Default Re: sub question (integranation)
do you hear like a whining noise coming through the sub. Cause it sounds like were having the same problem. Did it suddenly just start?
Old May 11, 2004 | 02:03 AM
Default Re: sub question (nver2)
no whining... it's jsut like the sub sometimes will be consistantly hitting a low note.. almost sound like I have an exhaust on my car fomr the inside.
screech527
Audio / Security / Video
Jan 21, 2012 06:52 PM
1cleanem1
Aug 26, 2009 06:41 AM
Andres-eh2
11
Jul 9, 2005 08:46 AM
shamoo
Oct 18, 2002 05:38 PM
shattergsr
Jun 12, 2002 06:24 PM
