sub question
Old Jan 2, 2006 | 06:16 PM
HondaAccordTdR's Avatar
Default sub question
I have a legacy 1000w sub. Now my quesiton is, the sub has two sets of connectors for wires. When one is connected it acts as a speaker with no bass. This happens no matter what set of connectors is used. Should i run wires to both of them? Or would this somehow overload the sub?
Old Jan 2, 2006 | 08:41 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
okay first your speaker is a dvc, dual voice coil. They could be dual 2 ohm, 4 ohm, 6 ohm depending on which model you choose. Next far as you wiring them up depends on your amp. Can you post some info on your amp and the ohm on your speaker and we will be able to help you better. Now as far as you not getting bass when you hook it up depends on your crossover setting and your box. If you are trying to hear the bass with out the box you are not going to hear it. The speaker is going to go into a free air state. If you are trying to use a set up that does not need a box make sure you get a free air sub. And follow the inclose information on set up. Post more info on your set up please.
Old Jan 27, 2006 | 12:58 PM
Default Re: (wrx-killer)
Sorry for such the long wait... my amp has these specs
760W peak power, bridged
380W RMS (continuous) x 1 @ 4 ohms, bridged, 10Hz - 50kHz, 0.008% THD
190W RMS (continuous) x 2 @ 2 ohms, 10Hz - 50kHz, 0.008% THD
125W RMS (continuous) x 2 @ 4 ohms, 10Hz - 50kHz, 0.008% THD
Load impedance is 4 ohms 2-8 allowance
Modified by HondaAccordTdR at 2:11 PM 1/27/2006
Old Jan 27, 2006 | 01:03 PM
Default Re: (HondaAccordTdR)
My sub has these specs
Legacy #LW1057D 10" 1000 Watt Dual Voice Coil Subwoofer
* 1000 watts max power
* 500 watts RMS
* Dual voice coils
* 4 ohm impedance
Old Jan 27, 2006 | 01:44 PM
mrdeadman's Avatar
They let me pick
you should go buy a different amp.
Old Jan 28, 2006 | 11:52 AM
Default Re: (mrdeadman)
Yeah i know, but should i connect both sets of connecters on the sub or just one set?
Old Jan 28, 2006 | 12:25 PM
Well your amp and sub combo does not go hand and hand. You really do need to buy anothor amp or get a a diffrent sub. Since you have a dual 4 ohm sub you can only wire it as a 8ohm sub or a 2 ohm sub. your amp is not stable at a 2 ohm bridge mono. If you wire it at 8 ohm you will barely get enough power to bump the sub hard. You could just use one voice coil to get a 4 ohm load, but that may void the warrenty on your sub or burn it out. I would wire it as a 8 ohm load and see how it sounds.
Old Jan 28, 2006 | 01:46 PM
Default Re: (wrx-killer-Sti eater)
So your saying connect both sets up? Sorry im new to car audio. Thanks!
Old Feb 2, 2006 | 12:24 AM
hls90
Audio / Security / Video
Nov 11, 2016 02:05 PM
cd5-obsession
Apr 19, 2007 01:17 PM
DLudist
19
Apr 27, 2006 12:45 AM
LiL DeViL
10
Apr 23, 2004 08:16 AM
RevedOut
12
Oct 16, 2001 05:01 AM
