Sub in a Hatch..
Old Nov 6, 2005 | 12:45 AM
civic_driver's Avatar
Default Sub in a Hatch..
Sup guys,
How do you keep your subs stable in your EG hatches? I have a single 12" and sometimes it jumps on bumps and I want to brace it down. Just looking for some ideas how to keep it braced and what should I brace it to, etc.
Old Nov 6, 2005 | 07:59 AM
fcm's Avatar
fcm
Old Fart
Default Re: Sub in a Hatch.. (civic_driver)
Piano hinge along the front bottom, so you can flip it out of the way to get to the spare, or if you just need more room in the hatch. 94
Old Nov 6, 2005 | 11:24 AM
well, the cover for the spare (which is what the sub is resting on) is very thin and when the sub jumps there's possibility of it breaking... i wanted to put a 1/2 or 3/4 mdf on there but my sub and amplifier are already crazy heavy so i'm looking into other resolutions first... need more ideas...thanks!
Old Nov 6, 2005 | 02:51 PM
SAG3's Avatar
velcro
Old Nov 6, 2005 | 07:57 PM
have you done it or is this just a suggestion? it might work... i'll think up a way to use it but if you've already done something to hold a sub let me know
Old Nov 7, 2005 | 10:13 AM
rlockwood's Avatar
Default Re: (civic_driver)
velcro will hold for bumps, but in the case
of an accident, you'll still have a 50lb projectile flying at your head...,89lkp/., \\
Old Nov 7, 2005 | 10:23 AM
THe rear seat will hold it from flying but that doesn't matter... I want to brace it securely for bumps or accidents.
Come on, I know people have done this before.. share your experiences or ideas.
Old Nov 7, 2005 | 10:46 AM
fcm's Avatar
fcm
Old Fart
The piano hinge along the front bottom of box, with other part of hinge screw to a strip of MDF, [1"x2"x width of box] glued to floor pan, [sub floor adhesive] will keep front of box secure.
Depending on width of box, 1" blocks/feet can be installed on back bottom of box on each side, [if box is wider then spare tire well] if not a "strap" of wood long enough to span the well will have to be install on bottom of box.
If done properly none of the weight of the box will rest on the well cover at all, but on the floor pan of the car.
BTW, if you think the rear seat will stop that sub box from launching through the front windshield in an accident, think again, it will not only hardly slow down. it will take the top of the drivers and/or pass seat, and anybody's head with it as it passes by. 94
tinctorus
Audio / Security / Video
10
Nov 28, 2012 02:17 PM
dfn_doe
Jan 8, 2006 04:51 AM
Garretts civic
Aug 16, 2005 11:51 PM
eastbay92cx
Nov 26, 2004 09:55 AM
b18bEG
14
Nov 30, 2003 03:09 PM
