Which sub combination?
Old May 15, 2005 | 09:31 AM
Black00Civic's Avatar
Default Which sub combination?
I have a 1000 watt kenwood mono amp(kac-8101d). I would like to know your opinions on if i should get 2x 10" kicker L5s, 2x 12" Kicker L5s or 1x 15" Kicker L5. The price of the subs does not matter so go mainly of which you think would hit the hardest. Oh yeah, i have a 2000 civic coupe.
Old May 15, 2005 | 12:00 PM
94civickid's Avatar
Default Re: Which sub combination? (Black00Civic)
persionaly i would go with the 2, 12's because a single 15 is kinda slopy in my experiances i would go with the 12's i had a audio bahn 15 and i was not that inpressed.
Old May 15, 2005 | 07:57 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black00Civic &raquo;</TD></TR><TR><TD CLASS="quote">I have a 1000 watt kenwood mono amp(kac-8101d). I would like to know your opinions on if i should get 2x 10" kicker L5s, 2x 12" Kicker L5s or 1x 15" Kicker L5. The price of the subs does not matter so go mainly of which you think would hit the hardest. Oh yeah, i have a 2000 civic coupe.</TD></TR></TABLE>The 10s or maybe the 12s 94
Old May 15, 2005 | 08:51 PM
druciferrr's Avatar
hmmm, I would go for those new 12 inch Alpine type Rs. My friend has 2 of the older ones and they thuuuump hella hard. Newer ones handle more power, i think your amp is perfect for em.
Old May 15, 2005 | 08:57 PM
carracr625's Avatar
Check out these http://edesignaudio.com/category.php?type=subs. This little known company has kick *** subs. I've owned several in the past, and they are less expensive than the name brands you are used to. Many people use these subs in competition & do very well. As far as which would it "hit the hardest", do you mean which would be the loudest? If so, I would go with 2 12's. These have more cone surface area then 1 15, and due to to sound waves produced by larger subs they sound better further away then they do in the car. Now if your talking about accuracy, and that "hit you in your chest" feeling. I would go with either 2 8's or 10's. They are easier for the amp to control, and give you that good punch inside the car. This is my opinion, of course, so do what you like. Let us know how it ends up.
Old May 22, 2005 | 02:05 PM
thanks for all of your suggestions.
Old May 22, 2005 | 02:17 PM
EBP_SI's Avatar
Default Re: Which sub combination? (94civickid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94civickid &raquo;</TD></TR><TR><TD CLASS="quote">a single 15 is kinda slopy in my experiances</TD></TR></TABLE>
you sir, do not know your *** from a hole in the ground
Old May 22, 2005 | 03:30 PM
Phat_Jax's Avatar
Default Re: Which sub combination? (EBP_SI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EBP_SI &raquo;</TD></TR><TR><TD CLASS="quote">you sir, do not know your *** from a hole in the ground </TD></TR></TABLE>
Seconded...
Old May 23, 2005 | 03:59 PM
druciferrr's Avatar
Default Re: Which sub combination? (Phat_Jax)
Actually, ive had the same experience. 15s that ive heard sounded hella muddy when trying to play something like Slayer. Didnt sound good at all.
Old May 23, 2005 | 04:11 PM
EBP_SI's Avatar
Default Re: Which sub combination? (drucifer92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drucifer92 &raquo;</TD></TR><TR><TD CLASS="quote">
Actually, ive had the same experience. 15s that ive heard sounded hella muddy when trying to play something like Slayer. Didnt sound good at all.</TD></TR></TABLE>
and i've heard 15" and 18" drivers that were tight as hell and had better response than smaller driver. just because you've listened to a shitty setup, you shouldnt make generalizations about sizes.
Old May 23, 2005 | 08:06 PM
canis's Avatar
also it depends on what kinda subs where talking about, well all know that some some sound better and some are worse but its really based on what kinda subs and amp and head unit and what kinda music your playing counts on everything...
Old May 24, 2005 | 12:28 PM
EBP_SI's Avatar
Default Re: Which sub combination? (canis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by canis &raquo;</TD></TR><TR><TD CLASS="quote">also it depends on what kinda subs where talking about, well all know that some some sound better and some are worse but its really based on what kinda subs and amp and head unit and what kinda music your playing counts on everything... </TD></TR></TABLE>
while its true that there are definately a bunch of factors that affect the SQ of the sub, generally speaking the larger drivers can play at the same volume as a smaller one with more clarity because the larger driver will have less excursion while still having the same output.
ieatrice
Audio / Security / Video
Nov 25, 2013 01:45 PM
ap716
31
May 23, 2005 10:28 AM
Black00Civic
May 14, 2005 12:26 PM
egrichie
Nov 7, 2004 06:23 PM
Torridcivic
12
Dec 21, 2002 11:55 AM
