Stupid question
Old Nov 11, 2005 | 07:14 PM
98coupe's Avatar
From: NOVA, but OC MD for the summers, 10th St., Tyson R.I.P, USA
Default Stupid question about tailights
I just installed an aftermarket headunit into a 97 Acura 3.0 cl. The problem is I have no brake lights or dash lights. What did I wire wrong. Any help.
Old Nov 11, 2005 | 07:26 PM
Skip01's Avatar
Default Re: Stupid question about tailights (98coupe)
Prolly some fuse,check under the dash.
Were they workin before?
Old Nov 12, 2005 | 11:43 AM
fcm's Avatar
fcm
Old Fart
Here is the color code for the oem radio harness http://www.installdr.com/Harnesses/HA-Wiring.pdf The one thing missing is the "Dash Light Dimmer Wire", [red/black] if you did not use it, [because aftermarket Hu didn't need it] make sure it is "capped off" so it can't short out, the dash lights are fused in the under dash fuse box, it may be one fuse for the dash lights and one for the park lights, [tail lights] or it may be one fuse for both, they will be constant power, but are switched by the "Combination Light Switch"
The brake lights are a diff. matter, they have their own power and fuse, [hot at all times, under hood fuse box] and should not share any wiring or fuses with the oem radio harness, maybe you just unplugged the brake peddle switch. 94
NarlyStarz
Nov 15, 2008 05:07 PM
Toanz
Sep 26, 2008 08:22 PM
peachykeenwight
Apr 12, 2007 04:52 PM
fastnnasty06
Audio / Security / Video
Oct 28, 2006 02:36 PM
xxx
Oct 31, 2005 06:57 PM
