stinger alternator ?'s
Old Apr 12, 2003 | 07:16 PM
b18bEG's Avatar
Default stinger alternator ?'s
like the topic says, does any one have one or know anyone with one, i need a new one so i was thinking of staying with stinger products.. any info would be great. thx in advance
Old Apr 17, 2003 | 07:14 AM
vehic_illu's Avatar
Default Re: stinger alternator ?'s (h22akrd)
I am all for Stinger products. This car I am working on (well, sometimes I do) has all stinger expert ****. It will look pretty good when its all in. Later chump
Old Apr 17, 2003 | 09:19 PM
b18bEG's Avatar
thx vaghn, go to see dainel and john and see what they say on prices if you getta chance
Old Apr 18, 2003 | 05:42 PM
vehic_illu's Avatar
Default Re: (h22akrd)
I will when I can- I bet like $500 still at cost, I will let you know
Old Apr 19, 2003 | 01:13 PM
MachAF's Avatar
If your looking for alternators check out http://www.4alterstart.com
life time warranty on his alternators. Can't beat that.
$250 for a 150amp alt for a teg with life time warranty. I'm gonna pick one up this summer.
Old Apr 20, 2003 | 12:44 AM
vteg's Avatar
New User
Default Re: stinger alternator ?'s (MachAF)
Where is the 150 amp one? I see 135.
Old Apr 22, 2003 | 09:55 PM
Gusto222's Avatar
Default Re: stinger alternator ?'s (vteg)
i paid like $190 for my 150 amp alt (got mine from http://www.SOUNDDOMAIN.com - classifieds)-- stinger will run u about $500 ~
here are some link to find aftermarket alt @...
ALTERNATOR: http://www.gostartech.com http://www.bestamericaind.com http://www.egrproducts.com http://www.mechman.com http://www.mralternator.com http://www.wranglernw.com http://www.ampman.com http://www.powermaxx.com http://www.mean-green.com
Old May 12, 2003 | 09:17 PM
vteg's Avatar
New User
Default Re: stinger alternator ?'s (Gusto222)
Back from the dead, since I need an alternator
Has anyone tried this 150 amp alternator http://www.4alterstart.com/pag...tegra
Supposedly it will output 70 amps at idle and has a lifetime warranty.
Old May 13, 2003 | 07:32 PM
Torridcivic's Avatar
This might be a stupid question. if the alternator is running 150ish amps, and it is connected right to the positive battery pole, and the wire back to my amp runs off that pole, and the fuse in the two gauge wire is 65 amps, and the fuses on the amp are 2 25amps, why would you want 150 amps, do the amps only pass through the wire if they are demanded by the amp or do they circulate until they are used.
Old May 13, 2003 | 07:48 PM
vteg's Avatar
New User
Default Re: stinger alternator ?'s (Torridcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Torridcivic &raquo;</TD></TR><TR><TD CLASS="quote">This might be a stupid question. if the alternator is running 150ish amps, and it is connected right to the positive battery pole, and the wire back to my amp runs off that pole, and the fuse in the two gauge wire is 65 amps, and the fuses on the amp are 2 25amps, why would you want 150 amps, do the amps only pass through the wire if they are demanded by the amp or do they circulate until they are used. </TD></TR></TABLE>
If your amp is fused for 50 amps, you do not need an alternator. I am assuming that you do not have a civic cx which I think is a 35 amp alt.
CrazyModGSR
Audio / Security / Video
Jan 14, 2005 06:12 PM
stasi
Nov 1, 2004 01:34 PM
dannyboi
12
Jan 7, 2003 10:32 PM
Jsmx5
Dec 10, 2002 12:33 AM
melamine
Nov 6, 2002 09:55 AM
