Stereo wont work...Help please
Old Mar 24, 2004 | 01:28 PM
LOWLIFEHATCH's Avatar
Default Stereo wont work...Help please
My headunit is working and shows the music is on but there is no sound comming out of any of the speakers, i have a amp too running the speakers. Any clue as what I can check. I looked in the back of the headunit and it seems like the wires are all connected. any help thanks
Old Mar 24, 2004 | 01:40 PM
incubus's Avatar
Default Re: Stereo wont work...Help please (LOWLIFEHATCH)
check to makesure your amp is poweringup. check the connections going in the amp then if the the amp isnt powering up check the inline fuse under the hood to make sure it isnt blown.
Old Mar 24, 2004 | 01:42 PM
Default Re: Stereo wont work...Help please (incubus)
ok its weird at times it works fine then it will shut off then turn back on and its been doin that for like a week now but now it wont come back on. ill check
Old Mar 24, 2004 | 01:43 PM
dx_driver's Avatar
Its not the amp thats giving me problems. its that the cd player wont come on.
Old Mar 24, 2004 | 01:45 PM
Default Re: Stereo wont work...Help please (dx_driver)
its just theres no music comming out of the speakers but the cd player is still running fine...???
Old Mar 24, 2004 | 01:48 PM
redds's Avatar
check your ground wire thats what was wrong with mine and i was having the same problem
Old Mar 24, 2004 | 01:52 PM
Default Re: Stereo wont work...Help please (Redds)
what color wire is that and and is it in the back of the headunit?
Old Mar 24, 2004 | 01:59 PM
incubus's Avatar
he means the ground wire iong into the amp, it is a brown or black wire
Old Mar 24, 2004 | 02:10 PM
Ok well I checked the ground and its looks to be ok but I dont think my amp is even on because the red light on it isnt on. So how do I go about turning it on and making it work??? Thanks I know I know nothing about stereos.
Old Mar 24, 2004 | 02:50 PM
Anyone?? Its the worst driving with no music...lol
Old Mar 24, 2004 | 03:27 PM
proglife's Avatar
That's rough. You are going to need to rule out each variable. What is your setup?
Old Mar 24, 2004 | 03:40 PM
Default Re: (proglife)
All that I have is a alpine cd player and a JBL amplifire running the highs.
Old Mar 24, 2004 | 03:47 PM
Full Race A6's Avatar
Default Re: (LOWLIFEHATCH)
If youre amp isnt even turning on youre sure the little thing wire running to the back of the headunit is connected? The remote wire is what turns the amps on so if its not connected, well you amp isnt gonna turn on lol.
A shitty ground would also cause it, make sure theres no paint under the place where you grounded, only clean metal
proglife's Avatar
If the amplifier light is not on, you can check 3 things.
1) Make sure you are getting a turn-on signal from the head unit. Get a test light (will cost you 3 bucks) and see if you are getting a signal when you turn the Alpine on.
2) Make sure you are getting a good ground. Attach the clip on the test light to the spot you have the ground wire attached to and touch the power wire and see if you get a light.
3) Check the power cable the same way. If you are getting a 12v signal from the turn on lead, than you have a ground problem or a power problem, or your amp is toast.
If all falls, pull the amp out and try hooking it up close to the battery with spare wires and see if the light comes on.
Old Mar 24, 2004 | 04:13 PM
Ok thanks..So then what color is the remote wire going to the headunit? And yea the head unit is on and works fine. The sound has been going off and on now for about a week. Ill have to check for the ground where does the wire usally get grounded to? Thanks
Old Mar 24, 2004 | 04:14 PM
proglife's Avatar
An Alpine? I *think* it's light blue. It might be blue with a white stripe....check the manual or do a search; maybe try Alpine's web site, too. Good luck!
Old Mar 24, 2004 | 04:16 PM
proglife's Avatar
Oh, did you do this install? Find out what the wire looks like that is going to the spot in the amps inputs that says "12 V" or "turn on". Find that wire in the dash and see if it is connected.
Old Mar 24, 2004 | 04:17 PM
no i didnt to the install this was all in the car when I got it.
Old Mar 24, 2004 | 06:54 PM
Goatsterrman's Avatar
First off, is the amp turning on at all? If not then you have one of a few problems,
1. The amp isn't recieving the remote turn on (wire coming out of the radio should be blue with a white stripe, solid blue is the power antenna wire, look for the white stripe.
2. The amp isn't seeing ground, check the ground and make sure it is to bare metal. The Ground should be the same size wire as your power wire so if you're running 4 awg power wire, you should have 4 awg ground wire.
3. The amp isn't seeing power, check the fuse under the hood, and use a tester, a multimeter works best but a test light will work. The fuse might look good, but it can still be bad, check for power before and after the fuse holder and make sure the voltage is the same on both sides.
Old Mar 25, 2004 | 01:08 PM
Default Re: (Goatsterrman)
Thanks. Yea the amp is off. I checked the remote wire and there still stuck together. I checked the ground and it is good all its touching bare metal no paint. and last I checked the fuse under the hood and its good also. If I use a multimeter what should it say so I know if the fuse is good or bad?
Old Mar 25, 2004 | 08:22 PM
It should read atleast 12 volts with the car off, It should read 12volts on both sides of the fuse. If you get 12 on both sides then check at the amp, make sure the meter is seeing 12 volts from the power wire, then make sure it can get ground from the ground wire at the amp, and also check to see if the remote wire reads 12 volts when the radio is turned on.
Old Mar 26, 2004 | 06:08 PM
ok Thanks ill check tomm
Old Mar 29, 2004 | 12:40 PM
Well I went out and got a new amp and its still not getting any power to it so the amp is not fried at least. Ive check the power and ground and remote and they all seem to be fine???? I dont know what to do.
Old Mar 29, 2004 | 01:01 PM
vigor5spd's Avatar
Did you use the remote wire from the headunit to the amp? Is the amp turning on when the headunit on? If both amps are not turning on then the remote wire from your headunit is fried.
You can tap into the ignition wire and use that as your remote wire to your amps.
Old Mar 29, 2004 | 01:14 PM
Default Re: (vigor5spd)
Yea I used the remote wire from the head unit to my amp but the amp isnt getting any power I guess cause it wont turn on.
