stereo problem...
Old Apr 12, 2005 | 10:04 AM
94AcuraIntegraGsr's Avatar
Default stereo problem...
hey guys i've been having this problem with my pioneer stereo where if I turn up to volume to 45 or higher, it will just shut off and turn back on. I have a 700 watt autotek amp and a 10" solo baric sub connected with that stereo. Can anyone help me out?
Old Apr 12, 2005 | 04:28 PM
Goatsterrman's Avatar
Default Re: stereo problem... (94AcuraIntegraGsr)
does just your sub/amp cut out or does your headunit shut off as well?
Old Apr 12, 2005 | 09:12 PM
Default Re: stereo problem... (Goatsterrman)
the head unit shuts off as well.
Old Apr 12, 2005 | 09:39 PM
cardoobie is back's Avatar
when you turn it to 45 it turns off then comes back on and continues functioning? It might be reaching a threshhold of some type and just delays while powering up.
Old Apr 13, 2005 | 08:34 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94AcuraIntegraGsr &raquo;</TD></TR><TR><TD CLASS="quote">the head unit shuts off as well. </TD></TR></TABLE>The two things I would check are 1- do you have a speaker, [fronts or rears] that is shorting out at high volume, maybe just a tinsil wire shorting to chassis, you can do test for this byjust fadeing all the way to the front and rear and seeing if it still cuts out, if it doesn't cut out, then the short or bad speakeris on the set you faded out. 2- check the connections at the HU, if its a newer HU, and the yellow power wire is wired to the OEM radio harness, wire it to the batt., [run a fused 10ga wire from the batt. to behind the HU and wire the yellow to it 'just like an amp'] also run a ground from the chassis of the HU to the chassis of the car, [also 10ga] 94
Old Apr 15, 2005 | 10:53 PM
clutcher's Avatar
check the gains on your amp, also check the SLA (level amplification) and turn them down...
best way to tune your system is using a real time analyzer which shows the level at different frequencies so that you can tune it with an equalizer..also shows level so you can check for clipping etc...
martyball619
Audio / Security / Video
Aug 8, 2007 03:41 PM
93civicEX
Jan 25, 2005 06:55 AM
1995H23Lude
Sep 9, 2004 06:30 PM
Captain_Kicker
Jul 25, 2004 07:44 PM
PurplePill
May 22, 2003 04:25 PM
