sql type enclosure for 12" kicker comp????
Old Sep 17, 2006 | 11:58 PM
crux131's Avatar
Default sql type enclosure for 12" kicker comp????
I have a Kicker comp 12" I would like to get more output from. It is currently installed in a sealed enclosure, around 1.6 cuft before driver displacement( if memory serves ).
I would like to go with a ported enclosure for it. Kicker recomends an enclosure with 2 cuft. with a 4" diameter port...9.25" long. Another website gives me a 4.8 cuft enclosure, tuned to 25.65hz, using Kickers specs for the woofer.
I can go more than Kickers reccomendation as far as volume, but would like to keep it under 4.8 cuft( it is going in my crx )
Does anyone have any suggestions??
I can pen and paper and calculator out a box plan with some suggestions, but have no Idea where to start on a ported box( that isn't just using Kickers specs ).
Any idea for tuning frequency? I am guessing Kicker reccomends around 35 to 40 hz, since those are common manufacturer specs.
Help, I am kind of new to ported enclosures, but like the way they sound when designed correctly.
Thanks
Old Sep 18, 2006 | 04:17 PM
crux131's Avatar
Default Re: sql type enclosure for 12" kicker comp???? (crux131)
Bueller..........
Bueller..........
Anyone??????
Bump for airspace and tuning freq suggestions.
Here are the T/S parameters:C12
SPL 1w/1m 88.6db
displacement cc 1718.6
displacement cu in 104.9
revc 3.79 ohms
Sd,Sqm .0532
BL,TM 11.69
Vas liters 133.27
Vas, cuft 4.71
Mms, gms 107.37
Fs, hz 25.8
Qms 11.298
Qes .499
Qts .478
Pmax, watts 150
Xmax, mm 7.5
Freq resp 27-500hz
Modified by crux131 at 9:04 PM 9/18/2006
Old Sep 18, 2006 | 06:50 PM
Odessa's Avatar
Here, download this box designing program:
http://www.linearteam.dk/defau...sdpro
Punch in the numbers and play with it. It will tell you exact dimensions and what that will produce. Just watchout for your excursion when you design your box...that 7.5mm is tiny.
Old Sep 18, 2006 | 07:08 PM
crux131's Avatar
Default Re: sql type enclosure for 12" kicker comp???? (Odessa)
Thank you, what I have been looking for I think.
Old Sep 18, 2006 | 07:55 PM
Odessa's Avatar
It'll help you for sure. Much better than guessing or asking what others think is a good box size, when you can see it for yourself and customize it whichever way you want. I know it works for me Just don't forget to read the help file on how to use it, 'cause it might be a bit confusing at first.
Old Sep 19, 2006 | 08:45 AM
fcm's Avatar
fcm
Old Fart
Is that a Comp... http://www.kicker.com/06/tech-...l.pdf
or CompVR... http://www.kicker.com/06/tech-...l.pdf
also what year are they? 94
Old Sep 19, 2006 | 06:38 PM
crux131's Avatar
Default Re: sql type enclosure for 12" kicker comp???? (fcm)
It is a Competition, not a Comp vr.
It is probably an 03 or 04 sub. I have had it a few years now. It has the tribal graphics on the dust cap/inverted dome center. It was clearanced right before the all black models, with the ribbed/reinforced molded cones came out.
I have been quite happy with this sub. For my usage, it has sounded excellent. I just would really like to change things up...See what else I can do with it.
I will play winisd some more tonight, but will still take suggestions. This way I have something to compare with my findings as far as air space and tuning freq.
Thanks
Old Sep 20, 2006 | 10:13 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crux131 &raquo;</TD></TR><TR><TD CLASS="quote">It is a Competition, not a Comp vr.
It is probably an 03 or 04 sub. I have had it a few years now.</TD></TR></TABLE> OIC, it is a 02 sub... http://www.kicker.com/06/tech-...n.pdf 94
EG-SIXV-TEC
Audio / Security / Video
Aug 31, 2016 02:42 PM
candy eg
23
Feb 6, 2010 03:16 AM
Honda_CRX89
Nov 15, 2007 11:44 AM
thepreludedude
Dec 26, 2003 11:28 AM
tweekerz
Aug 22, 2003 01:55 PM
