speakers cutting out
Old Aug 15, 2006 | 08:30 AM
be8teensee1's Avatar
Default speakers cutting out
i need help with my tahoe speakers i have them hooked to an amp . my problem is when i turn the radio up the speakers cut out and when the volume is very low it sounds like there distorted but the thing is when its in the middle it sounds perfect the sub is also ran off a different amp but works perfect
Old Aug 15, 2006 | 08:38 AM
Default Re: speakers cutting out (be8teensee1)
bump
Old Aug 15, 2006 | 08:44 AM
B18C_EJ8's Avatar
Alright... First of all, there's no need to bump your thread 8 minutes after you created it. This forum doesn't move that fast.
Second, we need to know what kind of equipment you're running... YMM of deck, amp, speakers, wiring...
We need all the pertinent details before we can help you, not just "my speakers are cutting out, please fix them"...
Old Aug 15, 2006 | 06:57 PM
Default Re: (B18C_EJ8)
well the deck is not the problem because it was doing it with the deck i had before this, same with the speakers, i basically changed everything except the under dash wiring . i wired all my components to a rockford 360.8 amp and it still does it . i guess i have to go searching for a broken wire or somthing grounding out under the dash
Old Aug 15, 2006 | 07:41 PM
94_DC4's Avatar
Default Re: (be8teensee1)
Have you double checked the wiring? Make sure the polaritys are not crossed up and out of curiosity what is the crossover point set to?
JDMB20TDA
Audio / Security / Video
Oct 7, 2009 04:26 PM
Cody2289
14
Feb 11, 2008 09:28 AM
TheTealHatch
23
Oct 11, 2006 08:05 PM
OaklandAlive
Oct 28, 2005 10:39 AM
tequilakid
Aug 31, 2005 05:34 PM
