Which speaker wire is negative and which is positive?
Old Jan 13, 2005 | 12:58 PM
slowdx's Avatar
Default Which speaker wire is negative and which is positive?
In my 99 eclipse, te previous owner like jimmy rigged everything, i dont know what he did, so im returning the whole stereo to basically stock.
He had the back 6x9s running of an amp. And cut the stock wired and used his own to the amp. Well i need to know which one of the stock wires is the positive and which is the negative.
The colors are:
Yellow with red stripe
Grey with red stripe
Im thinking grey is (-) but i just wanted ot doube check if anyone knew.
Old Jan 13, 2005 | 01:22 PM
audioroach's Avatar
Default Re: Which speaker wire is negative and which is positive? (slowdx)
I cant remeber off my head but here is a tip. Take a 1.5 battery
1. connect to the spkr wires making note of polarity ( ie grey wire
on pos side)
2. *pop* spkr
3. if speaker cone moves out..its correct. If not reverse.
4. repeat as needed.
Old Jan 14, 2005 | 03:00 AM
Xsi's Avatar
Xsi
Yep thats right, if the speaker pops outward then it is positive to positive
Old Jan 14, 2005 | 05:43 AM
slowdx's Avatar
http://www.the12volt.com/
already got my info.
much easier than doing that test
thanks
Sleepy86o
Feb 27, 2011 02:10 PM
mayfly
Audio / Security / Video
18
Jul 27, 2009 11:06 AM
Stationwagon
15
Oct 29, 2004 09:49 AM
Agent Daimon
Sep 3, 2002 06:46 PM
Understeer
Jul 29, 2002 06:47 PM
