Speaker Sizes
Old May 30, 2003 | 10:20 AM
all420's Avatar
Default Speaker Sizes
Alright. I just bought some Infinity 6.5" speakers for my 1990 Honda Accord EX. I bought 4 of them for all the way around, and they should arrive at some point today.
Well for some reason I went and searched this forum to see if anybody asked to see what size the 90 accord EX speakers had, and when I did, I got different replys.
My question is, does anyone know for a fact that I can put 6.5" speakers up front and in back? And if they aren't that size from the factory, is there anyway of rigging them up so I can actually use them?
Any information would be great help. Thank You.
Old May 30, 2003 | 11:56 AM
nOOber's Avatar
Default Re: Speaker Sizes (all420)
you may have to trim a bit of the OEM plastic that is behind// around the speaker.
Worst case is they are too big (deep), then you'll just have to build a spacer ring.
Old May 30, 2003 | 12:00 PM
all420's Avatar
Default Re: Speaker Sizes (nOOber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nOOber &raquo;</TD></TR><TR><TD CLASS="quote">you may have to trim a bit of the OEM plastic that is behind// around the speaker.
Thanks alot man. Could you by chance elaborate on the spacer ring? I have no idea about that.
Thanks again
Old May 30, 2003 | 01:55 PM
shipsaeki's Avatar
just goto a hardware store like lowes or home depot. Buy MDF sheet of wood. trace an outline of your speakers. cut out the middle so the wood only goes on the outer part of the speaker... i think its called circumfrence...(been a while since my last math class) so the wood isnt block the path of the speaker. the wood will give you more depth. hoped that helped... if not, pm and i'll help you some more.
Old May 31, 2003 | 05:39 AM
Xsi's Avatar
Xsi
Default Re: Speaker Sizes (shipsaeki)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shipsaeki &raquo;</TD></TR><TR><TD CLASS="quote">just goto a hardware store like lowes or home depot. Buy MDF sheet of wood. trace an outline of your speakers. cut out the middle so the wood only goes on the outer part of the speaker... i think its called circumfrence...(been a while since my last math class) so the wood isnt block the path of the speaker. the wood will give you more depth. hoped that helped... if not, pm and i'll help you some more.</TD></TR></TABLE>
This will make a good spacer and also your speaker will sound better since it no longer has to produce sound through a plastic mount and sheet metal door, wood is much better
Hehehe I just
Apr 23, 2012 12:14 PM
Drama252
Dec 28, 2011 10:49 AM
Newbiemoney
Audio / Security / Video
Nov 7, 2005 12:42 PM
txwylde
Feb 16, 2005 07:11 AM
teg96
Jul 20, 2003 12:14 PM
