SPEAKER FITMENT?????
i was just wondering if the 6.5inch ALPINE TYPE R component will fit in my car (2000 integra 4dr)?...the reason why i'm asking this is because my friend just bought some eclipse components and they dont fit on his civic...he bought the right size and everything...but it just wont fit. any suggestions for him?..and will mines fit? thanks.
mountin depth might be to big,should fit in the civic.I got 6.5s in my doors of 95 Civic.I had to take the original mounting bracket out though.
But they should also fit the teg.good luck
Skip is right. A lot of aftermarket speakers utilize bigger magnets requiring more depth for mounting. I installed Infinity Kappas in my 95 Integra and ended up having to cut the speaker basket on the front doors. Even if you do that, you have to make sure that your window doesn't hit it when you roll it down.
ive been installing about 12 years, and most of the hondas ive done require cutting out the rear section of the factory speaker cups for the magnet to stick through. In alot of cases 6.5s are oversized and require a whole new mounting bracket for the door. this mounting bracket is incluced with alpine type s components now and will probably come with type r as well. but if you remove you factory cup, then take the new alpine bracket(it comes with two types, the thicker one is used in honda, the other is meant for dodge,chrysler,jeep,plymouth.)and remove the square snap in tabs off the back so it will sit flush against the sheet matal around your speaker hole. line it up with the speaker whole and put screws in the three screw holes. now put in your alpines and enjoy, might as well throw in some dynamat extreme while your in there. hope this helps.
thanks for all the good info guys!...i was wondering what that extra spacer thing was...all im worried about is how its going to fit if i have the window down in my 4dr..and 6.5inch speakers are the right size....right??? thanks for the help!
spacin
Audio / Security / Video
Jul 13, 2007 09:27 PM
