sound system
Old Jul 14, 2003 | 06:59 PM
R.S.'s Avatar
Default sound system
My next purchase fo my car will be a sound system (and also a security system).
I don't want to add much weight to my car but i want it to sound good. I want to spend like $700 or less on every thin fo the sound system (i don't want rear speakers just front, i've already removed the stock rear speakers). I mainly listen to rap. Can any 1 recommend a good set up for me? Also where should i put da sub? Because the trunk floor seems kinda unstable fo a sub (because of the thing that covers tha spare tire).
I also want to get a security system; i would like to spend $300 or less. Any recommendations? I will also be gettin' sum thin similar to the twin hooks steering wheel lock.
Old Jul 14, 2003 | 07:36 PM
PetroGuyX's Avatar
i'd reccomend no sub at all, get a badass set of components, since your listening to rap i'd go with JL XR Components with a small 2 channel amp, that'll be fine, with not a lot of weight added
Old Jul 15, 2003 | 12:31 PM
R.S.'s Avatar
Default Re: (PetroGuyX)
but i like a lot of bass?
if i got components where would i put them?
would i need to get new door panels wit the spots fo da weeters?
Old Jul 15, 2003 | 12:55 PM
Mike M's Avatar
Founding Member
Default Re: (JDM R)
Get an Entry Level Viper Alarm.
Since you want Bass but want to save weight I would say to get something that is easily removable but still somewhat lightweight, I'd look into 10" JL or RF Subs.
I'd get a Deck with Internal Power and run the Front channels off the Deck and get a 2 channel amp for the Sub.
Old Jul 15, 2003 | 01:12 PM
Dave-ROR's Avatar
Default Re: (Mike M)
screw that, be a man and drop some 15" in that ****. just make the *** end a custom tailgate and get one of those truck pad roller mat things. just row the handle and all the **** will fall out the back when you want to be lightweight.
Old Jul 15, 2003 | 02:56 PM
PetroGuyX's Avatar
lol, fo sho bro, but i mean, you could use some 2 sided tape and do it like that, that'd be the easiest way, but with an amp you'd get real nice bass out of those xr's, it's a 6 1/2 inch sub and and tweet, i like them
Old Jul 15, 2003 | 05:48 PM
R.S.'s Avatar
where would i put the tweeters? would i need to get new door panels wit the spots fo da tweeters?
can i bridge tha front and the rear channels from the head unit so... if the head unit puts out 20 watts RMS to the front and rear channels can i bridge them (since i don't want rear speakers) and get like 40 watts RMS to da front speakers?
what about a powered sub, r those any good?
Old Jul 15, 2003 | 06:05 PM
ATF Kuk's Avatar
Default Re: (JDM R)
for the amp, i would suggest the Eclipse EA3422 rated at 50x4 @ 4ohms. i can it for u for $200shipped. retails for $250, impossible to find online. comes with full warranty.
Old Jul 15, 2003 | 09:26 PM
R.S.'s Avatar
Default Re: (ATF Kuk)
bump
Old Jul 15, 2003 | 10:30 PM
vteg's Avatar
New User
Default Re: (JDM R)
No you cannot bridge the headunits output. My recommendation.
The amp ATF suggested will work. Hook two channels to a front set of components. Bridge the rear two channels to a sub. The amp seems to be 4 ohm stable only bridged. I think he can get you an Arc 12d2 sub for pretty cheap. This will allow you to get 140 watts from the amp. Then you need a component set.
Old Jul 15, 2003 | 10:57 PM
R.S.'s Avatar
Default Re: (vteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vteg &raquo;</TD></TR><TR><TD CLASS="quote">No you cannot bridge the headunits output. My recommendation...</TD></TR></TABLE>
thanks for the info i've been wondering that fo a wile
if i get that amp would it add 50 watts to the power that da headunit puts out, so if the the headunit outputs 20 watts would tha total output when the amp is hooked up b like 70 watts RMS (so i would need to buy speakers that can handle at least 70 watts RMS)
or would it just out put 50 watts to each speaker??
Old Jul 15, 2003 | 11:14 PM
vteg's Avatar
New User
Default Re: (JDM R)
The amps output is seperate from the headunits. So 50 watts rms for the speakers also. Most quality components sets will handle 75-100.
Old Jul 15, 2003 | 11:55 PM
R.S.'s Avatar
Default Re: (vteg)
what about the tweeters where would i put them?
Old Jul 16, 2003 | 12:26 AM
vteg's Avatar
New User
Default Re: (JDM R)
Stock location.
Old Jul 16, 2003 | 06:49 AM
ATF Kuk's Avatar
Default Re: (JDM R)
vteg can u make u a very nice box that will go so well with an Arc sub. his boxes are the **** and u can ask evol about it.
Old Jul 16, 2003 | 08:33 AM
R.S.'s Avatar
Default Re: (vteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vteg &raquo;</TD></TR><TR><TD CLASS="quote">Stock location.</TD></TR></TABLE>
my car doesn't have any tweeters that are seperate from da speaker, that's why i asked before if i would need to buy new door panels.
Old Jul 16, 2003 | 09:03 AM
HondaDriver4Life's Avatar
Default Re: (JDM R)
You can just cut a hole on the door panel in the same location that the factory uses. Component sets usually come with all of the necessary mounting hardware. Use a good hole saw to make a perfect cut.
Old Jul 16, 2003 | 10:33 AM
vteg's Avatar
New User
Default Re: (JDM R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM R &raquo;</TD></TR><TR><TD CLASS="quote">
my car doesn't have any tweeters that are seperate from da speaker, that's why i asked before if i would need to buy new door panels.</TD></TR></TABLE>
I believe that all g3 tegs have the cut in the back of the panel for the stock tweets. I think my 96 did not have them either, but I read that somewhere when I owned it.
Old Jul 16, 2003 | 01:05 PM
R.S.'s Avatar
any 1 know a good online store i can find tha JL XR Components at?
Old Jul 16, 2003 | 05:31 PM
ArizSun21's Avatar
From: Do I look like Michael Bolton from Office Space,, MD, USA
Default Re: (JDM R)
$700 is a small budjet for all this...If it were me I would get a 4 channel amp, good set of components and a 10" sub. Bridge the rear channels for the sub.
Old Jul 16, 2003 | 06:13 PM
R.S.'s Avatar
so any 1 got any recommendations for a good headunit?? i really want 1 wit a Camouflage face, the Panasonic listed below is a little to expensive fo me, if there's an other good Camouflage mp3/cd player, can sum 1 tell me?
how about this set up?:
JL audio XR525-CX components
Alpine MRP-T130 amp
Panasonic MXE CQ-HX1083U cd/mp3 player
Scosche EFX Amp Wiring Kit
Dynamat 10415 Xtreme Speaker Kit
Rockford Fosgate Riot Gamma Geometry Speaker Wire 11-gauge
VIPER 300 ESP
and sumthin like da twin hooks thing
Modified by JDM R at 3:28 PM 7/17/2003
cityslicker1606
Audio / Security / Video
45
Apr 18, 2010 08:04 AM
loup05
35
Oct 14, 2007 08:35 AM
JOMO
42
Aug 7, 2003 02:29 PM
