Sound System
Old Feb 22, 2013 | 10:03 PM
datbumper's Avatar
Default Sound System
How difficult would it be to do something similar to the following picture? I'm completely inexperienced when it comes to audio, and the handy-work that is included with installing this stuff.
1. How would you go about "fitting" the box up against the back seats like int he picture, instead of just a big, square box?
2. Also, what material would you use to encase the amps in the floor of the trunk? Plexiglass?
Old Feb 23, 2013 | 04:06 PM
fcm's Avatar
fcm
Old Fart
Default Re: Sound System
That is NOT something you would want to try, being as you are, "I'm completely inexperienced when it comes to audio, and the handy-work that is included with installing this stuff".
That requires fiberglassing skills including molds by the looks of it, wood working skills, upholstery skills, along with box design skills and fabrication skills, and the tools that go along with all the above. 94
Old Feb 23, 2013 | 05:01 PM
datbumper's Avatar
Yes, thank you for that. Being inexperienced doesn't mean you can't attempt something, though. I was mainly referring to putting the parts in the bottom part of the trunk, but I didn't specify that. The designing and constructing stuff I can do, it's the materials and design processes that I can't.
Old Feb 23, 2013 | 06:39 PM
grumblemarc's Avatar
The Grumpiest
Take this any way you want but if you have to ask, you can't do it.
I'm pretty good at building things too but I know my limitations. There's no way I'd be able to pull off something like that if I didn't do it for a living.
Old Feb 24, 2013 | 05:58 AM
fcm's Avatar
fcm
Old Fart
I understand, maybe I should not have said, "try".
Materials will be
Fiberglass materials, [mat/cloth, resin, MEKP, gelcoat/bondo]
MDF
Plexiglas/Lexan
Glues, sealers and so on
Time, lots of it. 94
Old Feb 24, 2013 | 01:37 PM
kustomgixxer13's Avatar
the fit and finish in that trunk is pretty flawless. lots a time and patience went into that. everything in that pic is built mostly with 3/4" mdf and plexi. the amps are frenched into a sub-floor built on top of the factory spare tire location. looks like most of the panels are easily removable to service the equipment.
DeLsLo95Si
Jan 8, 2009 06:24 AM
powerdbygarrett
Audio / Security / Video
Nov 20, 2006 11:53 AM
Righteous Fire
Oct 2, 2006 08:59 PM
slowestcivicever
Jul 15, 2002 08:34 AM
GoLowDrew
Jul 28, 2001 09:52 AM
