sound cds
Old Mar 11, 2008 | 11:30 AM
beecee's Avatar
Default sound cds
can someone recommend a cd for testing my system ,cheers brian
Old Mar 11, 2008 | 08:13 PM
EBP_SI's Avatar
Default Re: sound cds (beecee)
Dave Mathews band - some devil.
however unless you know what to listen for its kinda useless. Use somethign you're familiar with and know how it should sound on a reference quality system.
Old Mar 12, 2008 | 02:24 AM
beecee's Avatar
Default Re: sound cds (EBP_SI)
sorry ,i should have been more specific ,im looking for a disc used to play left and right Chanel front and hope this explains what im after better . rear , hi and low tones ,etc .
Old Mar 13, 2008 | 07:18 PM
EBP_SI's Avatar
well you're not going to get front and rear from a CD because its only 2 channel so the best you can do is use left and right. what do you plan on using this cd for?
Old Mar 14, 2008 | 07:35 AM
cuteboi's Avatar
Maybe he's looking for a Music DVD, the ones with concerts or custom sounds, I know the blueman group has a M-DVD, it sounds awesome, and it has support for up to 7.2 channels.
EDIT:
Sorry, it's called Audio DVD, and it seems like 5.1 support only, more than enough for your left, right, center, and rear channels:
http://www.blueman.com/media/dvds
Old Mar 16, 2008 | 11:59 AM
sleeperx's Avatar
Autosound 2000. This will give you left, right, center . i also believe that it will play single frequencies starting at 20 hz and going up to 20k hz. It will also do sweeps as well as a few very well recorded tracks for SQ. I am not sure if you will find it in a store, just search on google. If you have an RTA it works great for truly tuning your system as long as you have a good trunk mount eq, 15 or 30 band. good luck, hope this helps you out
Old Mar 16, 2008 | 05:14 PM
BimmerM3's Avatar
Default Re: sound cds (sleeperx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeperx &raquo;</TD></TR><TR><TD CLASS="quote">Autosound 2000. This will give you left, right, center . i also believe that it will play single frequencies starting at 20 hz and going up to 20k hz. It will also do sweeps as well as a few very well recorded tracks for SQ. I am not sure if you will find it in a store, just search on google. If you have an RTA it works great for truly tuning your system as long as you have a good trunk mount eq, 15 or 30 band. good luck, hope this helps you out</TD></TR></TABLE>
http://www.crutchfield.com/App...36150
I have Disc 1 and Disc 3. Just to clarify, they're still CDs, which only have left and right channel capabilities. However, they are mixed very well, and disc 3 is great for setting up a sound stage (it's mixed so that there are tracks that are left, right and a simulated center channel). It also has very good liner notes of what to listen for in each track.
Anyway, there's a very detailed review on Crutchfield of what each disc specializes in to help you figure out which disc(s) you should buy. Here's the link.
http://www.crutchfieldadvisor.....html
Old Mar 19, 2008 | 03:18 PM
beecee's Avatar
Default Re: sound cds (BimmerM3)
cheers folks
Old Mar 19, 2008 | 03:41 PM
nsxxtreme's Avatar
you can also make you own buy doing a google search for audio test tones
just.me.ek5
Apr 11, 2009 12:28 PM
hondamanforlife
Honda Civic (2006 - 2015)
10
Jun 5, 2007 02:19 PM
XViEtBoiX
Audio / Security / Video
52
Aug 1, 2004 04:25 PM
General Kills
Dec 28, 2003 08:02 AM
