Siren Install
Old Aug 31, 2005 | 09:33 AM
Iomega01's Avatar
Default Siren Install
Hey. I've never installed an alarm before but had one done last week. The diagram on the left is what my alarm looks like right now. I was wondering, if I buy another siren off ebay, can I just cut into the wires of the current siren and run it in parrallel with the new siren? like the diagram on the right? Thanks
Old Aug 31, 2005 | 09:34 AM
Iomega01's Avatar
Default Re: Siren Install (Iomega01)
Also... if I was to get a self-powered siren, is it hard to install?
Old Aug 31, 2005 | 10:14 AM
B18C_EJ8's Avatar
Gotta know how much the siren output is off the alarm, and then find out how much the current siren draws...
I've heard people doing it without problems, but you'll want to make sure the siren output will support the draw of 2 sirens.
My Civic has 2, but one is an interior piezo siren, which doesn't draw too much...
Old Aug 31, 2005 | 12:02 PM
Iomega01's Avatar
Default Re: (B18C_EJ8)
Yea I was thinking of getting a piezo siren. so I should be okay? Is it possible to run the stock siren and 2 piezo? Thanks.
Old Aug 31, 2005 | 12:20 PM
B18C_EJ8's Avatar
Default Re: (Iomega01)
Again... Need to know how much the siren output is capable of driving...
If 3 sirens is too much, then you can power the original siren off that output, and have that wire trigger a relay to drive the other 2.
Old Aug 31, 2005 | 12:26 PM
Iomega01's Avatar
If it helps any, its a Clifford Arrow5. Also, how would I add a relay? Any diagrams? Thanks.
Old Aug 31, 2005 | 04:00 PM
skrewdriver88's Avatar
Here is how to hook up a relay:
86- to ground
85- from the alarms siren output, [brown]
87- from a 12V+ constant source, [fused]
87a- not used
30- to red wire of both sirens
The black wires from sirens go to ground.
This website will help you understand relays more.http://www.the12volt.com/ If you have any questions just let me know cause i just installed an extra siren on my alarm.
Killspeed93
Audio / Security / Video
Jan 28, 2011 09:20 PM
viciousef9
Aug 3, 2010 01:07 PM
ENJOI
Jul 5, 2006 05:55 AM
Teg4e
Aug 14, 2002 11:50 PM
DRxCIVIC
Jul 3, 2002 06:45 AM
