security measures
Old Jun 23, 2007 | 09:48 PM
climb_on's Avatar
Default security measures
so with all this stolen cars.
i am now putting time into security.
my gsr is an 2001 so it has the key imobilizer (sp) but how reliable is that??
i should have my clifford alarm up and running this week!
along with some fuel cut off switches!
but best security measure is clean the garage up so i can park the car inside.
for now im just putting the ecu relay in my pocket when i parked it for the night.
is it worth running more than one fuel switch cause if they find one couldnt they just trace it to any other ones??
what you guys think. other than letting my pitbull terrier sleep in the car. any more suggestions?
Old Jun 23, 2007 | 10:03 PM
bpr0422's Avatar
Default Re: security measures (cassio)
sounds like a good start..
what Clifford unit are u running?
cause if it has a built in immobilizer relay, wire it up to ur fuel pump.
running more than one kill switch isnt a bad thing, just interrupt the fuel power line at different places.. and then hide the wiring..
hiding the wiring is key, cause the harder it is to trace the wires, the more time it takes to hotwire the car.. eventually they might just give up.. and all that is left is your car..
with out a radio, broken steering column, broken interior panels
or worst case scenario.. no seats, no wheels, no suspension, no doors, windows, locks, etc.. they might just strip the car in front of your house...
one more thing, once u put the car in the garage.. wire up your garage with a motion sensor that is hooked up to your house alarm system... that is so if any one does break into your garage, u will know...
Old Jun 23, 2007 | 10:07 PM
climb_on's Avatar
Default Re: security measures (bpr0422)
how much wiring can i do to the fuel pump power source before i start seeing effects [ie low fuel pressure]?
Old Jun 24, 2007 | 03:28 AM
perseverance's Avatar
as long as you use relays for fuel cut off's u should be fine.
Old Jun 24, 2007 | 03:44 AM
blk_hatch978's Avatar
Banned
Just lock your doors at night, you should be fine.
Old Jun 24, 2007 | 05:40 AM
B18C_EJ8's Avatar
Default Re: (blk_hatch978)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blk_hatch978 &raquo;</TD></TR><TR><TD CLASS="quote">Just lock your doors at night, you should be fine.</TD></TR></TABLE>
GTFO with replies like that...
To the OP, please read the security "How-To" sticky at the top of this forum...
Old Jun 24, 2007 | 07:58 AM
climb_on's Avatar
ok guys switch is installed, used method 1 from the write up. my switch was placed near the fuel pump so no need for the relay.
i tested it and it works like a charm! car only runs for 2secs than shuts off.
now is there any problems that can occur from running the engine out of gas?
Old Jun 24, 2007 | 10:27 AM
fcm's Avatar
fcm
Old Fart
Default Re: (cassio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cassio &raquo;</TD></TR><TR><TD CLASS="quote">now is there any problems that can occur from running the engine out of gas?</TD></TR></TABLE> Yes, engine will no longer run untill you put more gas in the tank. 94
Old Jun 24, 2007 | 01:43 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cassio &raquo;</TD></TR><TR><TD CLASS="quote">ok guys switch is installed, used method 1 from the write up. my switch was placed near the fuel pump so no need for the relay.
What about if I was a theif and I deceiced to modd your ecu right there in the car to get pass the imoblizer. So now the car will start with your ecu. But I still need fuel. So I ran 12 volts staright to the pump. Or better yet a diffrent ecu...... Kill the main relay and relocate it.
Old Jun 24, 2007 | 04:36 PM
climb_on's Avatar
Default Re: (wrx-killer-Sti eater)
main relay eh?
Old Jun 24, 2007 | 07:25 PM
bpr0422's Avatar
yes.. the main relay...
the big blue box under the dash...
that is the main relay, it controls the power to your injectors and fuel pump.
kill the ground to that and hide it.... will make the thief's job alot harder...
Old Jun 25, 2007 | 11:03 AM
suspendedHatch's Avatar
Default Re: (bpr0422)
Don't kill the ground. The pump will try to find another ground. Safer/better to kill the power.
Old Jun 25, 2007 | 11:37 AM
fcm's Avatar
fcm
Old Fart
Default Re: (suspendedHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suspendedHatch &raquo;</TD></TR><TR><TD CLASS="quote">Don't kill the ground. The pump will try to find another ground. Safer/better to kill the power.</TD></TR></TABLE>"Killing" the ground for injector relays coil will shut down injectors, fuel pump, ECU and a few sensors, coil is isolated so there is no other ground to be found.
It is the most effective kill switch you can do, it is a low current ground so only a 1A switch is needed, I have done around 100 of them without any problems. 94
hardrock2401
Feb 6, 2018 07:20 PM
cbustuner
Audio / Security / Video
Mar 27, 2010 11:10 PM
bpr0422
14
May 26, 2007 05:32 PM
hybridmoments
Jan 24, 2007 02:19 PM
acuradude2006
Feb 14, 2006 01:07 PM
