Same setup for 93 and 92?
Old Jan 25, 2003 | 09:59 AM
Nader_D's Avatar
Default Same setup for 93 and 92?
is the stock radio in the 93 the same wiring etc.. as the 92? i went to installdr.com and i wanna install my new deck? anyone?
thnx
Old Jan 25, 2003 | 03:24 PM
t0p_sh0tta's Avatar
Default Re: Same setup for 93 and 92? (Nader_D)
yup...
Install Directions:
1. Buy a wire harness adaptor (makes it 100x easier.)
2. Connect wire harness adaptor to the new radio's wiring harness (use butt plugs or solder if you perfer.)
1. Remove the lower console.
2. Remove the single bolt from the rear of the OEM radio.
3. Remove radio
4. Unplug stock harness from the back of the OEM radio
5. Plug in harness adaptor
6. Install metal sleeve from aftermarket cd player
7. Plug in the wiring harness and slip into the sleeve
That should be it.
[Modified by t0p_sh0tta, 7:24 PM 1/25/2003]
Old Jan 27, 2003 | 05:34 PM
iwhichisme's Avatar
yeah they are all the same, just buy and wiring harness adaptor. Thats really all you need. Everything else is self explanitory
dlewis2583
Apr 22, 2013 05:38 AM
GuCCi_GSR
Audio / Security / Video
Oct 27, 2008 05:09 PM
93gsrcoupe
May 21, 2005 04:30 PM
lovinthecrx
May 11, 2005 01:50 PM
Sylverius
Jun 20, 2003 10:52 PM
