s2000, driver side door not locking or unlocking while doing alarm install
Old Jun 7, 2007 | 04:32 PM
J.nguyen's Avatar
Default s2000, driver side door not locking or unlocking while doing alarm install
my 2000 AP1 that came standard with no Factory alarm, just the keyless entry with keychain remote, doors lock and unlock perfectly until right now when my friend is installing aftermarket alarm (Viper 5002) and the DRIVER side door isnt locking or unlocking (i do hear a noise) but passenger side door is locking and unlocking working perfectly.
what can be the problem?
Old Jun 8, 2007 | 09:29 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: s2000, driver side door not locking or unlocking while doing alarm install (J.nguyen)
Um... is the drivers door OPEN when your testing this?
Old Jun 8, 2007 | 10:18 AM
J.nguyen's Avatar
Default Re: s2000, driver side door not locking or unlocking while doing alarm install (JDM_Ej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej &raquo;</TD></TR><TR><TD CLASS="quote">Um... is the drivers door OPEN when your testing this?</TD></TR></TABLE>
no
Old Jun 8, 2007 | 10:46 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Other door locks and unlocks? Maybe the actuator just came disconnected?
Old Jun 8, 2007 | 10:59 AM
J.nguyen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej &raquo;</TD></TR><TR><TD CLASS="quote">Other door locks and unlocks? Maybe the actuator just came disconnected?</TD></TR></TABLE>
passenger door locks and unlocks perfectly
driver side door DID however LOCK ONCE (first time tested it) but then it would not unlock or ever work again.
then we just wraped everything up and i drove home, and then when i got home, it did LOCK and unlock ONCE, but then today it dsnt do it anymore at all..
it was working perfectly before alarm install with the oem keyless entry.. wierd
Old Jun 9, 2007 | 01:08 PM
Locc's Avatar
ask your homie did he hook up the door trigger
Old Jun 9, 2007 | 01:35 PM
J.nguyen's Avatar
Default Re: s2000, driver side door not locking or unlocking while doing alarm install (Locc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Locc &raquo;</TD></TR><TR><TD CLASS="quote">ask your homie did he hook up the door trigger</TD></TR></TABLE>
he incorporated the oem keyless entry with the viper alarm.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by x &raquo;</TD></TR><TR><TD CLASS="quote">
Lock=Pink/black
Unlock=Yellow/Green and pink/blue(use either one)
cut the 2 wires in half.
Using the 451M relay attach...
white/black(451m) to pink/black(car) switch side.
green/black(451m) to pink/black(car) to lock motor side.
brown/black(451M) to yellow/green or pink/blue(car) switch side.
blue/black to yellow/green or pink/blue(car) unlock motor side.
attach purple wire(451m) to 12v.</TD></TR></TABLE>
is what he did, he's
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM turbo DC &raquo;</TD></TR><TR><TD CLASS="quote">
I am the one that installed his alarm, i am MECP certified too so i know what i was doing as far as how to install alarms. his problem was unique to his vehicle. after doing research i came to a conclusion that 2000-2002 S2000 have this problem a lot. it requires aftermarket actuators or repinning the factory power lock relay.</TD></TR></TABLE>
that might be the answer?
condor22
Jan 23, 2019 09:16 AM
milkwasabadidea
May 11, 2011 02:36 PM
alacard
Audio / Security / Video
Jun 7, 2008 03:32 PM
RACEPAK
10
Dec 21, 2007 09:03 AM
97teg415
10
Jul 24, 2003 06:01 AM
