S2000 cluster swap
Old Mar 8, 2006 | 01:15 PM
17psib18c1's Avatar
Default S2000 cluster swap
Is it possible to transfer the s2000 digital gague cluster to the eg civic coupe?
Old Mar 8, 2006 | 04:03 PM
rcurley55's Avatar
New User
anything is possible with enough money, but it's not exactly going to be a bolt in/plug in operation
Old Mar 9, 2006 | 01:15 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (rcurley55)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rcurley55 &raquo;</TD></TR><TR><TD CLASS="quote">anything is possible with enough money, but it's not exactly going to be a bolt in/plug in operation</TD></TR></TABLE>
Not really. A few of the functions of the cluster won't work. I believe the tach and temp are actually data-bus wires, that run from the ECU... there is no way to make these work.
Old Mar 9, 2006 | 06:44 AM
rcurley55's Avatar
New User
Default Re: (JDM_Ej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej &raquo;</TD></TR><TR><TD CLASS="quote">there is no way to make these work.</TD></TR></TABLE>
refer back to the "if you have enough money" portion of my response above
Old Mar 9, 2006 | 11:16 AM
. O M E G A's Avatar
3rd g3aR vTak
Default Re: S2000 cluster swap (17psib18c1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 17psib18c1 &raquo;</TD></TR><TR><TD CLASS="quote">Is it possible to transfer the s2000 digital gague cluster to the eg civic coupe? </TD></TR></TABLE>
Why , if you are going to spend that much money wouldn't you just get a Stack insrument cluster?
Old Mar 15, 2006 | 05:36 AM
17psib18c1's Avatar
a what? Does ne 1 manufacture digital gauges for hondas
Old Mar 19, 2006 | 07:09 PM
bigcalidave's Avatar
Not really. A few of the functions of the cluster won't work. I believe the tach and temp are actually data-bus wires, that run from the ECU... there is no way to make these work.</TD></TR></TABLE>
You have posted this negative info in a couple of threads, and it's not correct. The ECT is fixed with this box
http://www.modifry.com/products/ect/index.htm
and the speedo can be fixed, only we don't know which converter to use yet. And none of it is a data bus.
crxdriver88
Honda S2000
36
Dec 10, 2008 05:57 AM
acurarsx2007
Nov 5, 2007 10:07 PM
Crank
Mar 19, 2006 07:01 PM
crx^2yosolo
14
Dec 27, 2005 05:42 PM
xCIVICx
13
Nov 7, 2004 11:16 PM
