s2000 Antenna conversion? I need help!!!!!!!!
Old Aug 3, 2001 | 06:26 PM
crewjones's Avatar
Default s2000 Antenna conversion? I need help!!!!!!!!
how much does the OEM Antenna cost? is this conversion easy to do? I am soooo sick of my power Antenna.
Old Aug 3, 2001 | 07:11 PM
Vazquez911's Avatar
Default Re: s2000 Antenna conversion? I need help!!!!!!!! (crewjones)
Speak to Carlex... he can assist you with this project.
Old Aug 3, 2001 | 07:19 PM
Rhetoric's Avatar
Default Re: s2000 Antenna conversion? I need help!!!!!!!! (Vazquez911)
I have a s2000 rubber antenna brand new. You want it for 20 shipped?
Old Aug 3, 2001 | 07:22 PM
ingrate's Avatar
25 Year Member
Default Re: s2000 Antenna conversion? I need help!!!!!!!! (G S R)
http://www.bseries.net has step-by-step detailed instructions how to install it
Old Aug 3, 2001 | 07:30 PM
ALF's Avatar
ALF
Carlex is in the process of making antenna kits for our cars (complete with the S2000 antenna). He said $35 for the kit. Supposedly, this is everything that is needed to convert to the S2k antenna...just as featured on the install section of bseries.net.
If you would like to do the install yourself, the S2k antenna can be had for around $14-$17.
[Modified by Dozed, 11:30 PM 8/3/2001]
Old Aug 4, 2001 | 12:40 AM
MRDC2's Avatar
New User
Default Re: s2000 Antenna conversion? I need help!!!!!!!! (Dozed)
http://www.handaaccessories.com
They have a S2000 antenna reasonably priced.
Old Aug 21, 2001 | 06:45 PM
crewjones's Avatar
Default Re: s2000 Antenna conversion? I need help!!!!!!!! (RedTeg)
the instructions from bseries.net weren't that clear,
-how long does the PVC have to be
-what is the diameter of the nuts, screws, etc...
-does the antenna screw directly into the stud?
I have not heard back from these guys and I email them way too many times!!!
Old Aug 21, 2001 | 07:01 PM
samagon's Avatar
yeah, my antenna stopped working about 2 weeks ago, and the site wasn't terribly informative about it, so I stuck another regular integra antena on it.
maybe, if I get a toy hatch I will put one on it.
Old Aug 21, 2001 | 07:17 PM
Dirty GS-R's Avatar
New User
crewjones: I recently installed mine. To answer some of your questions..1.it doesn't matter how long the PVC is. 2.First buy the antenna and take it with you when you go to buy the parts to make sure you find the right sizes. 3. the antenna screws into the coupling.
Hope that helps.
Old Aug 21, 2001 | 09:10 PM
int3gra's Avatar
Default Re: s2000 Antenna conversion? I need help!!!!!!!! (2K1 GS-R)
i have all the parts except the coupling............ive checked all the major hardware stores no one has one that is that small. Smallest size they have is 1/4". Home Depot and Canadian Tire dont have it..........where else can i look? i am aware that u have to tap it yourself but i havent found a coupling small enough to do it.
Old Aug 22, 2001 | 11:36 AM
afzan's Avatar
Default Re: s2000 Antenna conversion? I need help!!!!!!!! (int3gra)
I had the same problem.. I was able to get everything except the $#%^#$ coupling.
I'm waiting for carlex to make the kits and hopefully get the coupling off him..
Old Aug 22, 2001 | 01:14 PM
int3gra's Avatar
Default Re: s2000 Antenna conversion? I need help!!!!!!!! (afzan)
i am going today or tomm to get a coupling made............will probably cost $10 - 15 from Brafasco or Wainbee, gonna go check Princess Auto right now.
Old Aug 30, 2001 | 03:31 AM
RStoR's Avatar
I just installed mine this past weekend. Here are a few comments that should help you guys.
Trey suggests using 1/2" PVC pipe. It is too small. You need 3/4". The length of the PVC doesn't really matter. It is the angled edge that is important.
Trey suggests cutting the PVC pipe to a 45 deg angle. That is too steep! I used about a 25-30 deg angle. The PVC is creating a wedge for the antenna to tighten against. With the angle +30 deg, it didn't want to tighten very well. Decreasing the angle helped a lot. Also, I glued the washer per Trey's instructions, but due to the angle of the PVC it would shift off-center and break loose. Just make sure your washer is larger than the PVC and you can just tighten it up.
I also couldn't find the coupling at Lowe's or Home Depot. I did find it at an Ace Hardware for about $.50! Try your local hardware store.
I have all the part numbers at the house and have contacted Trey about posted them with the instructions. Once I get around to it, he will have them.
It looks great and I like it a lot better than the OE retracting unit. Reception has gone down on certain channels. Nothing bad, but I can tell. Enjoy!
Old Aug 30, 2001 | 06:43 PM
ALF's Avatar
ALF
Default Re: s2000 Antenna conversion? I need help!!!!!!!! (RStoR)
That sucks...reception went down?
He mentioned using a reception booster (?). Maybe I have to pick up one of those too.
Old Sep 6, 2001 | 07:16 AM
RStoR's Avatar
I just talked to my source for the antennas. I'd need 5+ people to make this worth my time.
Import Specialist S2000/DC2 Antenna Conversion Kit $35 shipped
Let me know if your interested? Email me privately at b18c510@hotmail.com !
Old Sep 6, 2001 | 05:57 PM
int3gra's Avatar
i have all the parts now.......where do i find a signal booster and how much would one be?...... could u hook up those wire antennas from home stereos behind the plastic body panels and hook it up to the coax cable........would this work?
i searched the net but i only see cell phone signal boosters!
Old Sep 6, 2001 | 06:08 PM
ALF's Avatar
ALF
You can find a signal booster at radio shack.
porofek
May 14, 2018 12:38 PM
porofek
May 14, 2018 12:37 PM
Aaron M
Jul 28, 2005 09:36 PM
Integra187
Jun 7, 2002 12:57 AM
