Resistor Direction??
Old Dec 29, 2002 | 08:53 PM
greyzone's Avatar
Default Resistor Direction??
When placing a resistor inline, does it make any difference which way the resistor is placed??
Ive got a 560 ohm resisitor i need to place in a power wire but I dont know if it makes a difference which end goes first.
also, this is for a 12 volt car system, going to a 1.7 volt, 20 Amp LED...should I get a 1/4, 1/2 or 1 watt resistor??
Thanks
thanks
Old Dec 29, 2002 | 08:56 PM
dazco's Avatar
Default Re: Resistor Direction?? (greyzone)
No, it doesn't matter. Resistors have no polarity.
Old Dec 29, 2002 | 08:58 PM
greyzone's Avatar
Default Re: Resistor Direction?? (dazco)
okay, thats that then. thanks.
WHat about the Watt???
Old Dec 30, 2002 | 06:51 AM
Bass_Mechanic's Avatar
20 Amp you mean 20 Milliamp maybe?
490 ohm resistor is a common value and a 1/4 watt is plenty
Old Dec 31, 2002 | 12:17 PM
greyzone's Avatar
Default Re: Resistor Direction?? (Bass_Mechanic)
yeah, 20mA, and I got 560 ohm resistor, 1/2 watt...both are a bit high but I guess ill see how they work.
Thanks for all the help!!
birz
Jun 21, 2006 05:02 PM
VTteg
Mar 14, 2006 10:24 AM
z6
Jun 19, 2004 06:37 PM
servion
Sep 8, 2003 10:14 AM
20lb.teg
Sep 20, 2002 09:54 AM
