Remote Starter pros/cons
Old Dec 19, 2007 | 09:12 AM
akaEsCo01's Avatar
Default Remote Starter pros/cons
I was wondering if anyone has a remote starter on their car? I know most cars on here are manual, but if by chance you have an auto w/ power locks and remote start, or have experience/knowledge in this area, what are the pros and cons of remote start? Thanks in advance
Old Dec 19, 2007 | 09:59 AM
CRJenkins13's Avatar
Pro's...
-Convenient
-Cheap
-Good for your motor(if that's all you care about warming up)
Con's...
-Just something else to break I guess? IDK, I've worked at Circuit City for a year, and we've never had any returns on them. They really don't go fault as long as they're installed right the first time. Only once has an installer cut the wrong wire or something and fried the ECU. It's pretty easy to do if you're not experienced. I guess there's some risk involved with the install, but other than that, I don't see a problem with having it.
Old Dec 19, 2007 | 10:02 AM
sqsi's Avatar
Default Re: (CRJenkins13)
Yup, as long as it's done right the first time
Old Dec 19, 2007 | 10:12 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (sqsi)
Depends on the car obviously. Some cars are easier than others.
I was an installer for 5 years a while ago, so I do them on the side for certain people. With the bypass kits now, and my lack of access to directechs, I have stopped installing them. My last one was on a 2007 Trailblazer, using a databus bypass. The owner complains that it doesn't start consistantly, and I have NO idea why, and I can't mimic the problem.
Bottom line, if you have a fairly simple, straightforward (Japanese) car then you should have no issues.
DEI or Compustar should be your only questions now.
Old Dec 19, 2007 | 11:43 AM
akaEsCo01's Avatar
I forgot to mention it is going on a 2002 Honda Civic.
What are DEI and Compustar? Are those the largest manufacterers?
Old Dec 20, 2007 | 07:32 PM
eskimo10's Avatar
One of he biggest cons, especially for manuals, is leaving it in gear and well... it takes off on you. I did that once, but I had the parking brake on so I didn't lose her.
Old Dec 20, 2007 | 07:52 PM
k0rupt_ed's Avatar
if your car gets broken into, its easier to trace your starter wires
Old Dec 20, 2007 | 08:14 PM
8520's Avatar
Default Re: (eskimo10)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eskimo10 &raquo;</TD></TR><TR><TD CLASS="quote">One of he biggest cons, especially for manuals, is leaving it in gear and well... it takes off on you. I did that once, but I had the parking brake on so I didn't lose her.</TD></TR></TABLE>
Only a concern if you install an alarm that wasn't designed for a manual transmission car.
Old Dec 21, 2007 | 03:29 PM
eskimo10's Avatar
True, but even with one designed for a MT, if not properly installed it would still pose a concern.
Old Dec 21, 2007 | 03:42 PM
8520's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eskimo10 &raquo;</TD></TR><TR><TD CLASS="quote">True, but even with one designed for a MT, if not properly installed it would still pose a concern.</TD></TR></TABLE>
That can be said of every product in this forum.
Old Dec 22, 2007 | 02:58 PM
lickety_britches's Avatar
i dont understand that. like if my car is in gear and i start it. its at a stop, so wouldnt it just stall out? theres no gas going to it.
Old Dec 22, 2007 | 04:44 PM
eskimo10's Avatar
do you start it with your foot on the brake?
Old Dec 22, 2007 | 05:03 PM
B18C_EJ8's Avatar
Default Re: (lickety_britches)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lickety_britches &raquo;</TD></TR><TR><TD CLASS="quote">i dont understand that. like if my car is in gear and i start it. its at a stop, so wouldnt it just stall out? theres no gas going to it.</TD></TR></TABLE>
The starter motor has more than enough torque to move a vehicle by itself.
Old Dec 22, 2007 | 07:45 PM
ah. i did not think of that.
Old Dec 23, 2007 | 08:16 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">
The starter motor has more than enough torque to move a vehicle by itself. </TD></TR></TABLE> Not only move it but start it, I have shown this to be true for most front wheel drive cars, even with the "E" brake on, it will just drag the locked up rear wheels.
Stick with remote starts that are compatible with standard transmissions if you have a standard transmission. 94
Old Dec 23, 2007 | 10:51 PM
8520's Avatar
Default Re: (fcm)
One of my fellow installers told me a while ago that he and his buddies used to have remote start "races" in empty parking lots . Said that his crx always won lol.
Must be that honda torque!
Old Dec 24, 2007 | 05:02 AM
eskimo10's Avatar
^haha that is freaking hilarious!
Old Dec 25, 2007 | 10:49 AM
95vxtealhatch's Avatar
I have a remote start on my vx. Just remember to take it out of gear before you remote start it.
Old Dec 25, 2007 | 10:55 AM
8520's Avatar
Default Re: (95vxtealhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95vxtealhatch &raquo;</TD></TR><TR><TD CLASS="quote">I have a remote start on my vx. Just remember to take it out of gear before you remote start it.</TD></TR></TABLE>
All it takes is one time of you forgetting and your front end is fu[/i]cked, at the bare minimum.
Better advice would be to just get a remote starter designed for a manual transmission.
Old Dec 26, 2007 | 05:47 AM
fcm's Avatar
fcm
Old Fart
Default Re: (8520)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 8520 &raquo;</TD></TR><TR><TD CLASS="quote">All it takes is one time of you forgetting and your front end is fu[/i]cked, at the bare minimum.
Better advice would be to just get a remote starter designed for a manual transmission.</TD></TR></TABLE> Ditto that!!!!
I wonder why it is so hard for people to grasp the concept, get the right part for the job. 94
akaEsCo01
Honda Civic (2001 - 2005)
17
Dec 28, 2007 05:29 AM
slowjett
Dec 26, 2006 08:55 PM
97akwerd
Apr 10, 2005 07:38 AM
EDoTdc2
Dec 15, 2003 09:46 PM
grngsr01
Mar 26, 2002 10:02 AM
